Rebel T6
rhaggerty
Hey guys! I'm looking for an AC car inverter that will charge the batter for my T6 (LC-e10) and need to know how many watts I need. I have looked EVERYWHERE and cannot find how many watts the battery/charger pull. Please help me! Thanks so much!
The 12 - 17VA is the one you want. That is the number of watts (VA = volts * Amps = Watts)
150 W would be more than enough headroom!
8 REPLIES 8
John_SD
Whiz
I also have a Rebel T6 and I simply purchased an extra battery for it from B&H. I find that the Canon batteries seem to last a long time on a single charge. They are expensive at $49.95 but I won't buy knock-offs. Have  you considered just buying a spare battery or two?
The presumption would be that the OP is going to be away from a stationary AC power source for an extended period. Carrying one or two extra batteries may not be a sufficient response to that situation.
Bob
rhaggerty
Robert is correct, I will be on a 2 month road trip without access to electricity for lengths of time. Buying an extra battery, or 3, wouldn't really be the best option. Thanks!
kvbarkley
Look on the back of the unit. Here is an example from another charger:
If you use 110 V this one requires (.085 * 100) or 8.5 W for 220 it is .05*240 or 12 W.
IMG_5920.JPGThank you! This one has a couple sets of specs on the back. Based on your calculation, it sounds like I can get the 150 watt inverter and be a-ok. Thanks again!
leximarie1232
Hello,
So my Canon T6 connects to my computer fine to like transfer pictures in all but for remote viewing for recording and such it will not connect. I have tried many times with shutting off the wifi and turning the camera off and on but nothing seems to work. I was wondering if it is that I have the T6 and not the T6i or something else.
Thanks so much!
Lexi
@leximarie1232 wrote:
Hello,
Thanks so much!
Lexi
You really should start your own thread, instead of hijacking someone else’s thread, with a different issue, no less.
You could use the EOS Utility for remote shooting with the T6.  Make sure Live View shooting is enabled in the camera.
