03-27-2025
04:49 PM
08:04 AM
Hello. I was just wondering why does this person's phot look so much more clear than the ones I take? Does his camera have a higher megapixle number? I also feel like I was in focus too. The moose is the one I found the other one is mine of the bird. I used the sigma 150-600 with my canon camera eos rebel t3. Maybe I just need an updade.
Tell me what y'all think?
03-27-2025 06:03 PM - edited 03-27-2025 06:03 PM
What was the ISO for this image? It was a bit noisy, exposure is a bit dark and how much of a crop?
I ran it through Topaz and removed the noise and bumped the exposure a bit.
R3 ~ R5 ~ R6 Mk II ~ R50
Lenses: RF Trinity and others
Adobe and Topaz Suite for post processing
Personal Gallery
03-27-2025 06:38 PM
It is dangerous to compare an SOOC (straight out of camera) image to a "found" image because the supposedly "better" image could be an altered Frankenstein image. A friend of mine who is a Canon enthusiast produces otherworldly images, but his "image" is 99% of the time a Frankenstein of several images stitched together and then worked over like a Hollywood celebrity and their plastic surgeon. While Topazed (sic), Photoshopped, Lightroomed (sic) images are a person's prerogative, I prefer SOOC and I actually like some noise/grain in black-and-white/monochrome images. Thus, if you had an SOOC image and a friend shot the same subject at the same time with a same/similar lens and there was a radical difference, that would at least be a fair discussion i.e. apples-to-apples. The bird image is a bit dark, but given the hefty telephoto lens camera shake would be another factor to explore as a cause for less than adequate sharpness.
03-27-2025 06:48 PM
Thank you very much! I will take all of this into consideration.
03-27-2025 06:51 PM
I'll have to check out Topaz. Thank you so much! ISO was 1600. Now I think I had that way too high, haha. It was sorta dark out and I needed some light, but I see all that noise it introduced into the photo now.
03-27-2025 07:28 PM
Lee made some valid points, a lot of images are significantly modified in post production. I like Topaz or DXO to reduce noise when I have limited options to reduce noise because of a lack of light. I don't want to give up on the image so I grab the frame and run it through noise reduction. But I will say that he is correct, straight out of the camera is always the goal.
Good luck, keep shooting because it will only get better as you move forward.
Personal Gallery
03-27-2025 07:32 PM - edited 03-27-2025 07:32 PM
Thank you! I am definitely going to get topaz!
03-27-2025 07:58 PM
First off, a moose is a lot bigger target than a Robin, it may have been a bit easier, but again maybe not. We would need to see all of you shooting data to really analyze the photo. At a quick glance, it looks like there could be a little movement in your image. That could be due to too slow of a shutter speed, or just technique. Knowing the focal length, shutter speed, aperture and ISO of the shot can really be helpful. Good post processing and noise reduction can make a picture better, but if you start with a better picture to begin with, it will be even better.
03-27-2025 07:58 PM
Do you know any discounts for Topaz?
03-27-2025 08:08 PM
Thank You!
