04-20-2022
03:34 PM
09:28 AM
I just purchased a lens for my EOS Rebel T3i. The lens I purchase was the RF 14-35mm f/4L IS USM Ultra-Wide-Angle Zoom Lens for RF Mount Canon. The lens will not fit on the camera. Did I purchase the wrong lens?
04-20-2022 04:50 PM
Yes. RF lenses can only work with RF-mount cameras and cinema cameras.
Your camera can only work with EF or EF-S lenses. Hopefully you can return the item (though it is opened, so not sure on the return policy from where you bought it).
04-20-2022 08:41 PM
@rs-eos wrote:Yes. RF lenses can only work with RF-mount cameras and cinema cameras.
Hopefully, you have enough to upgrade your camera to an RP.
04-20-2022 09:00 PM - edited 04-20-2022 09:02 PM
Definitely you want another lens. Since you have a crop-sensor camera the best lenses would be: an EF-S type, which are specifically designed for this sensor- I have all of these and they are all great lenses.
Canon EF-S 17-55 f/2.8 IS USM - a very good lens - this is arguably Canon's best APS-C lens.
Canon EF-S 15-85mm f/3.5-5.6 slightly wider aperture, and a really good lens - I have two of them!
Canon EF-S 10-22mm f/3.5-4.5 gives you a range of wider angles if that is critical to you.
Definitely return the RF lens and get one of the above.
04-21-2022 03:11 AM - edited 04-21-2022 11:35 PM
04-21-2022 04:57 AM
Given the OP deliberately purchased a lens that was ultra-to-medium wide angle (14-35), the question is whether the 18-135, which is a good general-purpose unit, is really what they want. I deliberately looked at lenses that would be more in the range for which they showed a preference.
The EF-S10-22mm, for example, has an equivalent FoV of 16-35mm, which is VERY close to the range they chose and is, I suspect, as close as possible to their intent.
06-07-2024 10:26 PM
Hi
I also have T3i. From last few weeks I am researching to upgrade and found RF 24-70 f2.8
Two days ago I contacted Canon and they said I can use it with the adaptor. For some reason I contacted Canon again today, and this time the rep said I cannot. So now I am confuse. But for sure Canon has untrained staff and I cannot trust them completely.
Anyone has any idea about using the adapter?
Thank you
06-07-2024 11:43 PM - edited 06-07-2024 11:44 PM
Hi Kashfir:
For best results you should actually start your own thread, otherwise it gets confusing for all.
That said. You definitely CANNOT use an RF lens with any other cameras except R-series bodies. That means they will not work on your camera.
If you want a lens for your camera, consider an EF or EF-S (NOT an EF-M) lens. As a general purpose walk-around lens, good for some landscapes, social photography and portraits, I would suggest the
EF-S 18-135 f/3.5-5.6 IS USM: if you can't find a new one, there are lots of them available on the used market - consider KEH.COM.
06-08-2024 11:57 AM
I am sorry Tronhard,
I posted on this thread as the camera and the lens is same as my choices. I will continue on the new thread. My apologies 🙂
Thank you
06-08-2024 07:07 PM
No worries, thanks for making the effort! 🙂
