06-02-2024 10:12 PM
Aloha All,
Please help!
I was updating the latest firmware for my R5.
Something's gone wrong: the camera no longer works.
OFF > ON, black screen. Only P appears, on top, as a Mode.
Press MENU or Q and nothing happens.
When I connect the camera to my mac, the EOS Utility says nothing's attached.
Any thoughts?
Mahalo!
Cat
06-05-2024 10:48 PM
Oh that is awful! If the camera turns on, all is not lost. I found this…..
In order to reset your Canon EOS R5 camera using the power switch, you can follow these steps:Turn off the camera: Turn off the camera by sliding the power switch to the "OFF" position.Remove the battery: Open the battery compartment and remove the battery.Wait a few minutes: Wait for a few minutes before reinserting the battery into the camera.Turn on the camera: After reinserting the battery, slide the power switch to the "ON" position to turn on the camera.This process should reset the camera's settings and restore it to its default state
hope it works….
06-05-2024 10:48 PM
hope it works….
06-08-2024 07:49 PM
Mahalo! Appreciated!
06-09-2024 12:55 AM - edited 06-09-2024 12:56 AM
Did the above steps resolve your issue? 🤔
