03-25-2023
12:39 PM
12:50 PM
I have a Canon EOS r7 and the Canon EOS r6. I bought the Canon RF 50mm F1.8 STM lens. When I attach this lens to the Canon EOS r7 the AF changes to manual and I don't have an option of choosing between one-shot or servo. When I attach this lens to my R6, I can choose either one-shot or servo. Can anyone explain why this is happening?
07-16-2023 06:34 PM - edited 07-16-2023 06:38 PM
The EOS R7 has a switch on the camera body itself. That says AF/ MF on it. It is located to the right of the hand grip. When looking from the front of the camera.
03-25-2023 01:17 PM
Check the AF/MF switch on the camera body is set to AF. The lens doesn't have an AF/ MF switch on it that's why it focuses on the R6. To turn off Manual Focus on the R6 you must go through the camera menu. The body AF/MF switch only works for lenses without the AF/MF switch.
07-16-2023 06:24 PM
I do have the same problem.
On my R7, only MF i present - did you find a solution?
Working on RP and on a R7 my freind have.
07-17-2023 04:46 AM
Thank you very much. canon support wanted me to send the camera and lens in for service…
You solved the problem, Thank you.
07-17-2023 12:31 PM
If a lens has an AF/MF switch on it. The switch on the lens overrides the switch on the body. That switch only works for lenses without an AF/ MF switch on it.
