04-29-2024 10:46 AM
Hi, on an EOS R7, I've managed to customise buttons to bring up, say Picture Style, but it's seemingly all 11 options in the range.
Is there anyway I can discard the 9 options that I never use, so that the custom button just acts as a 'toggle' between the 2 options that I do use?
Many thanks.
04-29-2024 12:26 PM
Hi Steve,
There's no way to limit the available picture style choices on any of the cameras as far as I am aware.
I see that you have two possible "workarounds".
Firstly let's say that you use Standard, and Monochrome styles. They are a few clicks from each other in the list. I would suggest that you use one or two of the user defined picture styles and configure them as copies of standard and monochrome. Then you only need to swap between user defined 1 and 2.
04-29-2024 12:26 PM
Hi Steve,
04-29-2024 12:42 PM
Many thanks; much appreciated.
