03-29-2024
04:13 PM
08:19 AM
James_C
Hello,
I have an R7 and I was trying to connect it to the Camera Connect app so I could import some pictures from my camera to my iPhone. I'm able to connect to the app using bluetooth, but whenever I try to import photos or use any other functionality, the app says "Switching to a faster Wifi connection" which just hangs and never completes.
I've tried removing the camera from the app and re-registering it, deleted connection settings in my camera, and followed some steps to try to connect to the camera while it's off. None of these have solved my issue. Please let me know if anyone can help, thanks!
Camera Body: EOS R7 Firmware 1.4.0 (updated today)
iPhone Device/OS: iPhone 15 Pro iOS 17.3.1
05-01-2024 03:44 PM
Hi Rick, any advice on how to proceed? Should I reach out to Canon at this point?
05-01-2024 04:28 PM
I would call support so they can help you troubleshoot what could be happening here. Our team is available Monday through Saturday at 1-800-OK-CANON (800-652-2666).
05-02-2024 08:14 PM
Thanks 🙂
I'm sending my R7 in for repair. If you're having the same issue you probably should as well, or I can let you know how it resolves in a few weeks.
05-09-2024 03:04 PM
I am having the exact same problem, have you resolved it yet?
05-09-2024 03:06 PM
Hi, no resolution yet. Still need to ship my R7 back to the repair center. Will let you know what their conclusion is.
06-08-2024 03:36 PM
I sent my R7 in for repair, just got it back and the WiFi is working! Now when I get to that "Searching for access points" screen, it shows the "Searching" message for ~2 seconds and then shows me the camera's SSID. I was then able to successfully connect to the app on my phone. Canon repair team said the WiFi PCB was no longer functioning so they replaced it.
06-08-2024 03:39 PM
Check my message that I accepted as a solution!
06-14-2024 11:48 AM
Thank you for following up and providing a solution. I gave up after bringing to the shop and just being told it was the website so maybe I will re-visit it now. Thanks again.
07-16-2024 08:40 AM
hi, how is your replaced wifi PCB R7 now? unfortunately, i have exactly the same issue. And so sad to know that it seems like the only working solution (upon my research) is what happened to your case. Did they replaced the whole PCB mother board and how much will that cost?
04-01-2025 12:17 AM
I’m having trouble connecting my Canon R7 camera to Wi-Fi using the Camera Connect app after the latest firmware update. I’ve tried several times to connect, but it keeps failing. I bought the camera from Goodwill Bins New Jersey Store Locations and haven't had any issues until now. I need help with troubleshooting the connection process.
Possible Causes:
Firmware update might have caused connection issues
Incorrect network settings or credentials
Incompatibility between Camera Connect app version and the firmware
