12-02-2022 11:24 AM
The R7, and other R series cameras, forces electronic shutter for focus stacking. This prevents the use of flash for focus stacking. There is no really good reason for not allowing mechanical shutter for focus stacking and the choice of which shutter should be left up to the photographer, not the camera. Does anyone know of any workarounds that can allow the use of flash with the built-in focus stacking?
04-19-2024 05:45 PM
Perhaps they will implement this into the new R5 Mark II which should be unveiled next month, if the rumours are to be true. Hopefully after that some new firmware updates will bring the functionality to other bodies such as R7 and R6 mark ii.
04-27-2024 12:14 PM - edited 04-27-2024 12:17 PM
Not activating the flash in focus bracketing has nothing to do with sensor read-out speed. This is more like Canon crippling the other cameras to cause frustration to its Macro photography customers. Only the R3 can do it. The R3 has an extra option, " FLASH " button in the focus bracketing settings. When the flash option is set to "0 sec", the flash will rapidly fire to match each highspeed shot. When set to "1 sec" the flash fires every second. I test it with the new EL-5 Speedlite and an R3 at Wex photos in the UK.
Olympus OM camera is the way to go for macro photography. Many macro photographers are selling their Canon gears and buying Olympus cameras for macro photography. Olympus is cheaper, lighter, and smaller, plus much better macro results. I shall leave Canon in the past.
Here is a list of Olympus cameras that fire the flash in focus bracketing.
05-26-2024 02:36 PM
I agree canon could easily add this via software update to other R cameras, I have been so tempted to dump canon and go to Olympus just for the Macro abilities but Im too invested, I have recently added a power pack to my twin head flash and can get 100+ burst images on low power just do not have the bracket option i have to manually pump and hope.
04-27-2024 12:30 PM - edited 04-27-2024 12:31 PM
Adapt. Use a video light. It will capture the entire sequence in less than a second in most scenarios. BFFFT, and you’re done. You just might be able to capture more shots on a single charge of the video light compared to the flash.
04-27-2024 12:44 PM
No video light out there is portable and will give great macro results as a flash paired with a professional macro diffuser like the Cygnustech macro flash diffuser. Focus bracketing with flash and a diffuser is the best method for capturing high-def macro shots in the macro world.
Check out the results from the Olympus OM camera with flash focus bracketing.
04-27-2024 01:01 PM - edited 04-27-2024 01:03 PM
The best macro shots are definitely taken using focus bracketing with flash. By Olympus OM system users. Canon has no rival. And No answer. When will Canon address this omission and provide it? They will lose many more macro photographers to Olympus if they don’t. Are you listening Canon? Give us some positive news if you want to keep us brand loyal!
05-25-2024 10:27 PM
This video shows you *DO NOT* need in camera bracketing. He uses manual lenses and the lean method to make his stacks. You can do this with any camera...and, objectively, get better IQ and more resolution with a number of cameras, including the R7, that simply is not possible with m4/3 format cameras. Its good to understand that all m/43 cameras are, are little sensors giving an equivalent fov to cropping larger format images made with apsc, full frame or medium formats. They dont provide "more reach".
Lastly, "professional diffusers" is not cygnustech or any of the overpriced pieces of plastic new macro shooters are buying. You can, and many of us have for years, make diffusers that do just as good of a job for $5. Cygnustech and AK literally took the concave diffuser design principles many of us were using 10 - 15 years ago. Here is a link from years ago with people showing their DIY solutions. I have also shared one of my photos made with like $3 worth of material for the diffuser.
https://www.dpreview.com/forums/thread/3953465
05-26-2024 09:01 AM
Not everyone has many time to spend creating a DIY diffuser. I prefer to pay someone who has done all the experiments and offers a great device. I have many money, so I bought a new Canon R3, now I can fire the flash in the mechanical shutter for macro.
05-26-2024 11:19 AM
You missed my point entirely. Its not about the cost. Its about you saying what "pros" do is buy overpriced pieces of plastic as part of their gear kit. I maintain there is skill involved in all aspects of making an image and not just buying overpriced prefab gear and relying on automation with a repeatable formula. Im not opposed to that stuff being out there for people who lack the time or skills and understanding to adapt to all scenerios....building diffusers was...and still is part of the craft. You need to learn and understand the principles of lighting to make good diffusers...but its also that learning that allows some of us to visualize an image and create it, or come across a tricky subject or scenerio and not be limited to a single lighting solution.
05-26-2024 07:35 AM - edited 05-26-2024 07:43 AM
@TattooTroy wrote:No video light out there is portable and will give great macro results as a flash paired with a professional macro diffuser like the Cygnustech macro flash diffuser. Focus bracketing with flash and a diffuser is the best method for capturing high-def macro shots in the macro world.
Did you watch your video before you posted it? Around the 5:00 mark he explains that he is not even using focus bracketing because he is using manual focus lenses.
“ No video light out there is portable… “
BTW, there is a wide selection of on-camera, video lights that mount on a hot shoe like a strobe, or on a lens like a ring macro light. They range in price from $25 to $2500 kits.
