08-26-2023 08:13 AM
I recently got the R6 mark II.
In the 'ISO speed settings' I get an option to set a max. shutter speed, and not a min. shutter speed (as is the case with my 5D mark III).
Is there no longer a way to set a minimum shutter speed? Is there a way around it?
I use this option in low light when I want the camera to stay within certain ISO ranges without going under a set shutter speed.
TYIA
08-26-2023
11:02 AM
11:12 AM
I've just set mine to Dutch, it looks like a translation glitch. It still works as it should and sets the minimum rather than max.
08-26-2023 09:11 AM
Have you explained that the right way around. It gives the chance to set the minimum shutter speed but not the maximum. Well it does on mine. Surely if you wanted to restrict the max shutter setting, you'd do it in tab 2 of the orange menu.
08-26-2023 10:00 AM
Is this what you are looking for? From the manual:
08-26-2023 10:45 AM
The OP is saying he only has a setting for Maximum. Your screen shot shows it as it is. Only minimum.
08-26-2023 10:52 AM
This is my screen. It's in Dutch, as that's my mother tongue.
The manual in Dutch does mention the max. shutter speed... I found a Youtube video that showed the option of a min. shutter speed. I'm really confused...
08-26-2023
11:02 AM
11:12 AM
08-26-2023 11:09 AM
Thanks for checking that! It didn't cross my mind that it would be that, but I'm glad it is 🤣
08-26-2023 11:15 AM
It's the same for German too. 😂
08-26-2023 11:16 AM
Oh gosh... Feels like a Google-Translate error 🤐
