07-08-2025 02:31 PM
Ok, I need to admit that I am stumped and can't find an answer in the manual (pages 601 - 607). Guessing the answer is buried elsewhere, but I can't find it. I'm sure someone here knows what I am missing/not think of.
I've owned the R6 Mk ll for over a year and a half, have shot thousands of photos, and erased images at least a couple times per month... from BOTH cards. I should add that card #1 is set up for RAW, and card #2 is set for JPEG (due to rare times that I need the JPEG).
Erasing all images on the card > Blue menu > #1 > Erase all images on card.... Typically I always have the option of choosing either card 1 or card 2 somewhere along the line, and my typically routine is to erase one, then the other. However recently (about a month ago) the card icon in the upper right of this menu page only shows card 2. I can't figure out how to get it to go to card one. I'll erase card 2 (because that is showing) then back out, then go in again to erase card 1, but the camera says No Images and still shows card 2. I have to switch the cards to opposite slots, then it will give me the option to erase again. I don't see anywhere to switch cards in this menu.
Things to note...
* Images are added to both cards still when I shoot.
* One card is not faulty because when I switch cards to opposite slots, same thing happens not letting me erase whichever card is in slot 1. I've tried two totally different cards as well.
* If I go to the part of the menu to Format, then I can see both cards, and can format both.
This is going to sound incredibly stupid (so go ahead and tell me so - lol) but for years I've been erasing the cards on any camera pretty much by muscle memory without paying a heck of a lot of attention. So I honestly cannot tell you what I was doing to switch from card 1 to card 2 for erasing, but I can tell you there was a way that was so simple that I was doing it without thinking.
Maybe I need to switch back to regular coffee instead of the recent switch to decaf? 🙂
The image below is a screenshot of the manual. My actual camera menu only shows Card 2.
07-09-2025 10:08 AM
The format option is something I use on occasion, but in addition to "erase all" I often use the option if I just want to erase a batch of images from both cards and leave the rest - so formatting won't work. For example I always leave client shots on the card as a third backup until a project is over (as well as backed up to a main, and a secondary drive - don't ask, some things I'm over cautious on. lol), but I might have a couple hundred images from a car show that I want to erase to make more room.
The swaping of cards is what I have been doing recently, but this has only been recently. I'm honestly not sure if something changed with the last firmware update, but I doubt it since that was a bit further back when I updated it. Minor inconvenience, I know... and it's not the end of the world, but what did change that I have to do this now?
You're supposed to tell your wife "I'm just cleaning your camera for you!" 🙂
07-09-2025 10:37 AM
I just checked, and the menu still is set up this way. It actually has been since November 2023 when I set the camera up to record RAW on the first card and JPEG on the second card.
So as an experiment, I changed the settings, turned off the camera, turned it back on, reset the settings to these again... it is still only letting me erase one card unless I swap cards to opposite slots.
07-09-2025 10:44 AM
"I've seen a few posts this year of people asking (some complaining) why can't I just erase both cards at once? "
Just to clarify, Rick... I don't want to erase both at once. The menu says "Erase all images on card 2" followed by "Cancel" or "OK" options. In the past, once I erased one card, I had the option in this menu of going to the other card. I no longer do. I have to physically switch card slots to erase (in whole, or in part) images from the other card.
I'm kind of like you with removing images, especially client images. I'll have everything uploaded to my iMac hard drive AND to a second backup drive... but still keep the images on the card until the client has everything AND the sale is a few weeks past complete. Then, only the cards get erased - and I still have copies on two hard drives.
07-09-2025 10:45 AM
My fault for not adding to the original post that more often than not, I'm just erasing a batch of images on each card, not the entire card. Sometimes I type faster than my brain thinks. lol
07-09-2025 12:32 PM
“ My fault for not adding to the original post that more often than not, I'm just erasing a batch of images on each card, not the entire card. Sometimes I type faster than my brain thinks. “
It sounds like you may need to invest in more memory cards.
It is inadvisable to erase a batch of images from the memory card in the camera. You can lose data and corrupt images. The camera is not as hood as a computer at file management.
I have never had an issue deleting the last image I took. It is when you begin deleting from the middle of the deck is when you open yourself up to trouble.
My memory cards serve one primary function. They record the images that the camera captures. If I wish to delete multiple images, then I will download all files on the card to my computer, and delete them there. Once I confirm that all files have been successfully uploaded, then I might reformat the card.
But, more times than not I don’t have the time to verify every file. I will install a “new” card in the camera and verify the photo download at another time.
07-10-2025 10:43 AM
I do have plenty of memory cards, actually more than I really need - 6 each 64GB for the R6m2, 3 each 64GB for the single slot Canons, and 2 each 32GB for the older Pentax DSLRs... and all marked for which camera they go with. While I do rotate them in each camera, I've always been horrible at thinking "Well, this one has images of the She Runs Marathon, so I'll pull that out while I take photos of the Northern Lights, and use a different card." They all get thrown on the same card (or dual cards) until I need to upload them to my iMac, edit them, back them up, and for the hired jobs, turn them over to clients - then I know it's safe to format. I know, it's really not a proper system or workflow, and seems stupidly disorganized (or as my best friend calls it "Idiotically disorganized chaos"), but it works for me.
Also, you are correct my friend that it is not a good practice erasing a bunch of images from the middle of a card... but it's a habit I developed about 20 years ago, and do it often. It started while shooting a marathon from behind the finish line when one of the other pros started doing it during a break of incoming runners. A few of us picked up on the (bad) habit, and have been doing it since, even though others have warned me it's not the best thing. Yes, I've been lucky for 20 years of doing this with no loss of data or images, and one day my luck will run out (it always does eventually, doesn't it?). But hey... there are worse habits I could have - some of the photographers smoke during these breaks. I'd rather damage the health of my cards than my lungs - lol.
Since I mentioned being disorganized at times, here is one to make you laugh. Yesterday my wife and I decided to go out to Lake Michigan to watch the sunset, and later the stars at night (last minute "let's go right now" type of thing). Packing beach chairs, camera bags, dinner & drinks in a cooler, warm clothes because we know 80 degree temps would drop to 60 after dark. Get to the beach, and that's when I noticed the camera bags that I grabbed didn't have my Pentax DSLRs, but two film cameras instead. Luckily both had film, but only 4 shots left on the Kodak Duaflex, and about 10 shots left on the Pentax 17. At least we still had fun. lol
07-10-2025 08:48 PM
Justadude,
Sounds like a wonderful evening at the beach. Here in East Texas we are still in the 90's at 9:00PM. Enjoyed your story. At least remember to take a camera. I would have probably have forgotten the camera.
Reese
