12-16-2020 04:21 PM
Bought an R6 on 12/06 to use for Christmas. Today 10 days later while updating the firmware to 120 using a 64 GB SDXC II card and update from canon website, after 2 minutes of download the following message appears on the screen "Firmware Update Program Update file cannot be found Please check the memory card and reloade the battery and try again." So I turn the camera off and the message is still on the screen. The camera can't be turned off. I remove the battery, the camera goes off. Following the message I put in a new "fully charged" battery with no memory card (the first was fully charged too) and immediatly the screen lights up with the same message even though the camera is in the off position on the indicator wheel. Contacted Canon and they said ship it to them in So. California. Christmas is next week and California is shut down (this is why I don't play the lottery). Has anyone else run into this problem. I will now have to revert to my Sony VX 2000. Not happy with canon at all. ![]()
12-30-2020 01:13 PM - edited 12-30-2020 01:20 PM
Here is what you are after in night time sky photography.
Unfortunately for me, the clouds prevented me from getting the S/J conjunction.
12-30-2020 01:17 PM
However you can do some funsy photos, like King on the Mountain!
These are good practice photos.
12-30-2020 01:18 PM
12-30-2020 01:19 PM
One thing I have found over the years, decades, is photo gear, cameras and lenses, etc., generally do exactly what you tell them to.
12-30-2020 01:25 PM
"BTW on a tri pod ISO 200 F4, 1.6 s"
What lens was it? Your ISO is way, way too low most likely. The shots I displayed as samples are ISO 1600 or about. The f4 is OK but f2.8 is better usually. A SS of 1.6 depends on the lens FL if star trails are not wanted, or wanted. It could be fine or not.
I can't give exact settings without being there with you but these are starters. Again bracket your shots. Bracketing is your friend.
12-30-2020 01:29 PM
12-30-2020 01:35 PM
12-30-2020 01:38 PM
