R5 firmware update — camera no longer works
catsongs
Enthusiast
Aloha All,
Please help!
I was updating the latest firmware for my R5.
Something's gone wrong: the camera no longer works.
OFF > ON, black screen. Only P appears, on top, as a Mode.
Press MENU or Q and nothing happens.
When I connect the camera to my mac, the EOS Utility says nothing's attached.
Any thoughts?
Mahalo!
Cat
iCollector
Oh that is awful! If the camera turns on, all is not lost. I found this…..
In order to reset your Canon EOS R5 camera using the power switch, you can follow these steps:Turn off the camera: Turn off the camera by sliding the power switch to the "OFF" position.Remove the battery: Open the battery compartment and remove the battery.Wait a few minutes: Wait for a few minutes before reinserting the battery into the camera.Turn on the camera: After reinserting the battery, slide the power switch to the "ON" position to turn on the camera.This process should reset the camera's settings and restore it to its default state
hope it works….
3 REPLIES 3
iCollector
hope it works….
Mahalo! Appreciated!
Did the above steps resolve your issue?  🤔
