08-15-2023 11:02 AM
08-15-2023 07:17 PM - edited 08-15-2023 07:20 PM
Make sure Wi-Fi and Bluetooth communications are disabled in the camera. I have heard that Dropbox does interfere with camera communications via USB.
Could you use a memory card reader connected to your computer USB port to transfer files from the memory card to your computer, or do you need to use a Canon utility? I always use a card reader for this purpose.
08-15-2023 08:16 PM
Thanks. But I also tried these way and it didn't work. I need Utility for camera liveview.
08-15-2023 10:00 PM
Have you tried connecting to your computer using Wi-Fi? Maybe that will work instead of the USB cable. The EOS Utility supports Wi-Fi connections.
08-15-2023 10:52 PM
WiFi is still fine but the speed is too low. I can also use C1. But sometime need Utility. Dont know why Canon has left this big problem for a flagship model like R5. In my R5 community, most of members have the same problem.
08-15-2023 11:28 PM - edited 08-15-2023 11:29 PM
If you connect the camera to your computer via USB cable, can you see the memory card contents in your computer's file explorer (or whatever the Mac OS calls it)? You should be able to see the camera's card that way.
That would show whether the USB connection is working to the computer.
09-09-2023 09:44 AM
Hi, I am having the same issue. I have a brand new R5, updated the firmware, updated utility, brand new tether tools cable. If i shut down my mac and turn on again sometimes i get a connection, then I lose it and it comes up with a connection error message. I work with food so need to shoot quickly before it spolis and this weeks jobs have been an absolute nightmare. I never had this issue with my 5d3. Honestly feeling like I've made a huge, very expensive mistake. If you find a solution please coudl you let me know. Thanks so much !!
09-11-2023 07:32 PM
Greetings louisetatton,
Per your description, you have performed the troubleshooting steps that we would have suggested. Please also check to ensure that Wi-Fi is disabled on the camera prior to connecting the camera to your computer with a USB cable.
Please also check to ensure that there isn't other apps on the computer that are trying to communicate with the camera when attempting to use the EOS Utility software application.
09-11-2023 08:52 PM
I work with food too. This is absolutely disaster for us.
Turn off Dropbox apps and all apps related image (preview, photoshop, finder...) before connecting the camera. While tethering, you can open these apps later but remember to turn off them all when connecting again (change battery, memory card...)
09-11-2023 09:08 PM
So turning off Dropbox as I suggested previously resolved your issue?
