06-15-2024 07:53 PM - last edited on 06-18-2024 09:18 AM by Danny
My Canon R5 Mode dial is stuck on FV. I have reset all previously set functions, and replaced the battery with a fully charged one. No change.
Any one else has had issues with the Mode dial?
06-15-2024 09:35 PM
The first thing I would do is a full camera reset, main and custom settings. If you have a large number of customized settings, you can make a backup to an SD card before the resets.
If this doesn't help, this could be a build up of skin oils, moisture, dirt, grit or other foreign debris. It could also be a hardware issue / button failure.
Grab a few old business cards and be very gentle. See if you can work the corners gently around the crevices of the button and dial. You can follow with a rocket blower.
If none of this helps, you'll need to contact Canon support to have the camera inspected.
~CarePaks Are Worth It
