01-24-2019 10:18 PM
Trying to use a pistol grip on my 60D, when I attach the remote cord the camera starts making a noise like it is trying to focus but can't and when I try to shoot from the pistol grip I get nothing. Anyone ever used the pistol grip?
01-25-2019 12:41 AM - edited 01-25-2019 12:59 AM
It sounds like your pistol grip is broken or not connected properly.
Is is it new? Have you used it successfully before?
Does it have the proper E3 connection?
01-25-2019 11:18 AM
It is new, I believe I have the proper cord and I have never used it yet. Once attached the only thing that happens is camera makes the noise like it is trying to focus constant clikcing noise and no power at the trigger. Of course there were no directions either and I have googled and found very limited information. Is there a particular setting I have to be on to use the pistol grip?
01-25-2019 11:38 AM - edited 01-25-2019 11:40 AM
There is no setting for wired remote control. The pistol grip is just another type of remote control shutter switch. It seems like your pistol grip has an electrical short or jammed switch.
Plugging in the remote cable should do nothing as long as it is plugged into the correct remote shutter terminal.
01-25-2019 12:35 PM
@MikeSowsun wrote:There is no setting for wired remote control. The pistol grip is just another type of remote control shutter switch. It seems like your pistol grip has an electrical short or jammed switch.
The remote trigger doesn't begin to fit my definition of a pistol grip. Is everybody talking about the same thing here? Is this "pistol grip" a Canon product or Brand X?
01-25-2019 03:22 PM - edited 01-25-2019 04:14 PM
This is what I assumed the original poster was talking about.
01-28-2019 09:24 PM - edited 01-28-2019 09:26 PM
You are correct this is exactly what I am tryig to figure out how to use. My daughter plays softball and having the handle with a trigger release would make it so much better for my wrists! I am not sure what I am doing wrong but I am not ready to give up yet.
01-25-2019 04:03 PM
01-25-2019 04:13 PM - edited 01-25-2019 04:16 PM
No, as soon as you plug in a wired remote, it will shoot no matter what drive mode is set.
