01-23-2021 03:02 PM
I'm having quite the connundrum, and I need to figure out if it's user error or camera fault.
Any time I switch my Canon 80D to the manual setting mode, any picture turns out pure white that I take. I've tried every setting I can think of. If I crank the aperture all the way up I can see some detail, but the picture still turns out almost completely white.
Am I correct in assuming that this is a shutter problem of some sort?
What's weird is that the camera works on the auto settings, but obviously auto isn't why I bought a thousand dollar camera.
Any help is very much appreciate!
Jim
01-23-2021 03:40 PM
@MrSpaceTeacher wrote:I'm having quite the connundrum, and I need to figure out if it's user error or camera fault.
Jim
The shutter wouldn't know what mode you were in.
Do you have exposure compensation turned on or have a high ISO set?
If a methodical check of settings doesn't reveal the problem reset all camera settings and custom settings.
01-23-2021 03:41 PM
What are you taking a photo of? Are you indoors or outside? Do you have the ISO value set very high?
Try this... outdoors when sunny, set to f/16, ISO 100 and 1/100 (or 1/125) shutter. That should expose fairly well.
01-23-2021 03:52 PM
Do you understand manual mode? You need to find the right shutter speed to match the aperture you choose in Manual mode & that's done by using the light meter reading you see in the viewfinder display. An all white photo pretty much says to me overexposed which is too slow a shutter speed. That can be the chosen shutter speed, too much exposure compensation or a mix of both.
01-23-2021 04:31 PM
I have a basic understanding, but I am indeed learning.
Thank you for the information!
I bring up the shutter because this is exactly the same issue a friend was having with his 80D, and it was a malfunctioning shutter.
However, I do believe I can eliminate this possibilty (which is good news) because the camera works fine on the automatic settings as seen in this picture below. This is just a test image. I'm going to try defaulting my settings and see if that works for me.
01-23-2021 04:41 PM
Also pay attention to your ISO. A high ISO will overexpose too compared to the same other settings at a low ISO.
01-23-2021 04:48 PM
@cicopo wrote:Also pay attention to your ISO. A high ISO will overexpose too compared to the same other settings at a low ISO.
Thank you very much.
I suspected ISO initially, so I had it way down toward 100.
I do believe I am not paying attention to my light meter near enough. I'm very new to it.
01-23-2021 05:10 PM
We all start off as rookies. Have you watched this?
http://www.canonoutsideofauto.ca/
01-23-2021 06:26 PM - edited 01-23-2021 06:54 PM
The sample image above shot in full Auto does not look right to me.
Please perform a full reset of your camera settings.
What I see:
Auto Lighting Optimizer.
White Balance.
I intially though EV settings as well, but don't believe this applies except for P, Tv, Av or M mode.
The 80D should be capable of more. Much more in auto, even when shooting into the sun like you are .
Something is off
01-23-2021 10:19 PM
You may want to look at these series of videos from Canon at least once or twice.
https://youtube.com/playlist?list=PLp-znpQge8HxrllwXwn9B0Xxf1f7BQnXC
You will want to have your fully charged camera nearby. I recommend a comfortable chair and a tripod.
