01-08-2021
02:30 PM
10:29 AM
I have been taking a lot of photos lately. I use the plug-in for the USB port to download from the memory card. When I go to review the photos, I find that each photo has a copy designated as XXXX (1). I hate to take the time to delete each one as unneeded. Is there something in the camera or laptop computer that is doing this? TIA.
01-11-2021 01:55 PM
01-11-2021 02:32 PM
I'll just do the sequence I mentioned before. I have photos that will be separated into different categories/files for future reference. If I can get my grandson here, he should be able to help.
01-16-2021 10:03 AM
To add to the problem, I was browsing through photos and found a bunch that had the original and two duplicates!
08-20-2022 11:01 PM
yes me too
my r6 suddenly started taking 3 shots every time i press the shutter
i fiddled with the settings, found something that asked me how many photos i want to take each time i press the shutter but it wouldnt let me choose 1, the lowest was 2
so now i am getting 2 shots for each press very annoying
i would love to know how to fix this
08-21-2022 06:27 AM
Sounds like you might have multiple exposure or HDR settings engaged.
While I would normally suggest resetting the camera, this time I am going to suggest you step through each of the Menu settings so that you can learn what the settings are and what they do.
You should also open the manual on your computer and have that available as you step through the Menus.
cam.start.canon : For customers using the EOS R6
08-21-2022 05:33 PM
I always delete them when I see they are safely downloaded. I do not reformat the card. Should be a good practice. Thanks for the tip.
08-21-2022 05:40 PM
I was looking for a reference to the formatting card issue but can't seem to find the context. So, at the risk of repeating - I strongly recommend the following:
1. remove your card from the camera, and install the image files to your computer's hard disc
2. once achieved, Eject the card, don't just pull it out, and reinstall in your camera
3. Format the card clean. Just deleting files will cause accumulating errors and eventually corrupt your card. If you do it when you put the card back in, you know your card is clean for the next shoot.
08-21-2022 09:20 PM
no they are jpegs
having enough trouble with them let alone raw
it just takes the photo twice i desperately want to stop it it takes up too much room on the computer and takes forever to delete them all
08-21-2022 09:21 PM
if it is a computer problem then why doesnt this happen with my 6D and my 7 mark ii?
08-21-2022 09:48 PM - edited 08-21-2022 09:51 PM
There is a lot of information here and some of it is confusing to follow as it covers different topics and there is also material from @Paulamc that should be in its own thread as there is no proof that the underlying cause is the same and it's just confusing this thread for everyone. I suspect the two posters may actually be dealing with different issues and they are certainly using different camera systems. So, in my responses I am just going to address the issues described by the @TinType_18 as he is the OP.
From what I understand so far, the issue appears after the files have been copied to a computer or other storage device. Can you please confirm this by checking the original files on your card? If they are not identified as xxxx(1) etc. on the card, then the issue is a computer one.
