10-17-2025 09:16 AM
So, I am a new person to this, and I only am using the defaults I think, (I'm borrowing it from my photography club) but when I tried loading the images from my microSD using the adapter, to my computer, every single jpg says it cant read the file correctly! Is there anything wrong with it? And if so, what's the solution?? Thank you for helping!!
10-17-2025 09:27 AM
It is my understanding tgat some have reported issues using a micro SD card via an SD card adapter VS a "real" SD card. I'll let the more knowledgeable ones here be more specific. I've never used a micro SD. I haven't really seen the need.
10-17-2025 09:33 AM
Indeed, better to use a normal SD card. Sometimes a different cardreader or cable can make a difference .Do the photos look normal in camera? If so you could use a usb cable from camera to computer.
(not meant as critisism but you state you're new at this, are they really jpeg's, if set to RAW you need different software)
