02-29-2024 06:31 PM
Every time I take a shot, the picture will flash for a second or so but the LCD screen then goes to the level indicator (which normally does not appear unless I toggled the INFO button).
I can't seem to get it to stop doing this. Any suggestions?
03-01-2024 07:06 AM
Yes. When the level displays, press INFO to switch to another display mode such as the Quick menu screen. Then, after taking a shot, you should briefly see the captured image, then it should return to displaying the Quick menu screen.
Basically, the camera will remember the last-used screen as set by INFO.
I can replicate this on my EOS 5D IV:
02-29-2024 07:45 PM
Welcome to the forum!
Are you using the OVF or Live View?
What is being displayed on the rear screen prior to taking a shot?
Try switching the camera shooting mode to Intelligent Auto, the Green Square. Does the issue still persist, or does it go away?
02-29-2024 08:37 PM
Good diagnostic questions -- made me pay attention to everything.
I am using OVF. Right now the level indicator is essentially the default on the LCD -- it is there when I turn on the camera, only goes away briefly to display the shot, then reappears. If I press the INFO button, it goes to the MENU menu. Oddly, I suddenly can't remember what is normally on there in between shots but it has never been either the level indicator nor the MENU screen. I am used to having the screen show various camera settings (shutter,r speed, shooting mode, white balance, etc.)
03-01-2024 12:03 AM
Do you have the Full Instruction Manual for the camera? The PDF file is at:
https://gdlp01.c-wss.com/gds/9/0300027469/05/eos6d-mk2-im4-en.pdf
Pages 73-86 discuss all the options for setting review time, displaying the level, Info Button use, Info screen, Quick Control screen, etc.
Have you changed settings for anything that affects what you're seeing and when? Maybe a reset to factory defaults, and starting there, is what you need to do.
03-01-2024 04:26 AM
Yes, I have the manual and am one of those people who actually reads it fully and often, so your advice is appreciated.! have gone through it on this issue and cannot seem to find anything.
I did a reset of factory settings a few days ago so it has taken my faulty memory a bit to recall what is different. Right now, every time I take a picture, once the display photo timer runs out (I have it set to five seconds) it reverts to the electronic level. What I want (and thought I had before) is that it wold revert to the Control View screen. I cannot find an option that allows me to set it that way.
03-01-2024 07:06 AM
03-01-2024 07:44 AM
Duh. That did it. Forgot that the camera does not have a default mode per se on the screen; it simply returns to whatever was on the screen last before the shot. Thanks.
03-01-2024 07:46 AM
Glad that solved the issue and that this wasn't some hardware failure!
