12-31-2024 08:40 AM
I just got my new mirrorless yesterday. First mirrorless camera and am excited to use it. However, when I took it out of the box I heard a little rattle-like noise. So gently shaking the camera body I can hear something that sounds like a plastic part moving back and forth in a loose fitting frame. Is that normal?
12-31-2024 09:44 AM
That's the IBIS, and it is normal. I found that out on mine after a mild panic attack - lol.
12-31-2024 10:13 AM
The rattle is normal. It goes away once you install a lens and turn on the camera. When you turn the camera off with a lens attached there isn’t any rattle.
Be sure to always turn the camera off when you install or remove a lens.
12-31-2024 09:44 AM
12-31-2024 10:13 AM
12-31-2024 11:34 AM
I agree with the previous comments, that’s the IBIS . I own the same camera and it’s not an issue especially once the camera is powered on with a lens. I believe the user manual also mentions this.
12-31-2024 01:11 PM
Good heavens, I had the same panic attack. So happy to know its normal.
Rusty
12-31-2024 01:12 PM
So happy to learn that!
12-31-2024 02:12 PM
Well, the panic attack isn't normal - just the rattling. 🙂
12-31-2024 02:17 PM
Well, yes and no.
If you have IBIS turned on with the lens attached and power on, you'll still hear the rattle.
If you have the IBIS turned off when a lens is attached and the power is on (I normally have IBIS off)... I still hear the rattle.
