New 90D built in flash problem
JRC
In Movie Mode the built in flash still pops up.
It should be automatically disabled in Movie Mode I believe.
Is that a defect? I think so.
JRC
Okay, supposedly this is a "feature" of the 90D. Flash can pop up in any mode.
This was not the case with the 70D which allows the flash pop up button to be disabled and remapped
for a different function. That's progress.
Thank you for the comments and assistance.
JRC, over and out.
12 REPLIES 12
kvbarkley
VIP
VIP
Do you have "disco flash" focus assist turned on? That might be why it is popping up. Try turning it off.
Its true, the flash cannot be used while recording movies.  Page 163 of the 90D's Manual
To confirm, I would recommend resetting the camera to default setings and with the flash down, change to Movie Mode.  If it pops up, you might have found a bug.  If not, you might have changed something or in conjuction with other settings (like exposure compensation) which caused the behavior.  Should be fairly easy to determine.
So funny  LoL!  Thanks KV got a good chuckle before walking out the door.
JRC
Thank you for your comment.
I'll try a reset and post a reply later.
JRC
I did a camera reset. No change, flash still able to pop up in Movie Mode. Defect.
Bug, not defect.  Since the camera is new, I'd contact Canon.  They could fix in a subsequent FW release.
They won't however, if they don't know about it or its not reported.
JRC
Thanks, Canon is aware of it.
Even though the flash can't be used when shooting video, is it possible that the auto-focus assist beam (or "disco flash" if you prefer) can be enabled as a focus assist for low-light video shooting?
That's not an issue, I have a light.
