10-15-2024 02:28 PM
I have noticed the appearance of vertical green lines across the images, which, after some research, I believe is related to a fault in the sensor. As this issue is affecting the quality of the images and my ability to use the camera, I would like to replace the ccd sensor.
Can anyone please tell me what will be the cost to replace the sensor?
Thanks
Shuvo
10-16-2024 02:00 PM
Open a repair request as the other stated. You will get an estimate when this is complete. Canon will need to inspect the camera and get approval before any repairs are performed.
10-15-2024 02:44 PM
Are you sure its not the memory card causing the problem. A faulty memory card can appear to be a bad image sensor. Also cameras haven't used a CCD sensor for years I mean back to the original EOS-1D camera.
10-15-2024 09:22 PM
Thanks for your response. I checked and It's not the card issue. Sorry it's will be CMOS sensor.
The sensors pixel is damaged and need to replace.
Thanks again.
10-16-2024 01:06 PM
How did you check in Live view?
10-16-2024 01:12 PM
Go to Canon's website and set up a service ticket.
Laser damage?
Rodger
10-16-2024 01:19 PM
It's most probably laser damage...... 😞
10-16-2024 02:00 PM
10-16-2024 02:10 PM
Thank you so much for your kind response.
