03-20-2014 06:45 AM
I just got an EOS 6D camera yesterday and the battery is not charging...
Should I return the kit?
What could be the problem?
Thanks,
Tamara
03-20-2014 11:19 AM
if you just bought it then it's better to return it. You may find a fix now, but if it happens again later you're too late. It could be there is something wrong with the battery or the charger, we don't really know for sure.
03-20-2014 11:22 AM
What color are the lights on the charger when you put it in?
03-20-2014 04:08 PM
03-20-2014 05:02 PM - edited 03-20-2014 05:05 PM
The normal blink isn't very fast, it sounds like an error that Canon issued a statementon late last year. I thought there was eventually a recall, but I couldn't find anything online.
Have a read at this:
http://www.usa.canon.com/cusa/support/consumer?pageKeyCode=prdAdvDetail&docId=0901e024809ed436
Edit: did you buy it from online, major store, or small store? If it's local I'd probably just go exchange it instead of fuss with a troublesome battery. If online, I'd probably give that a shot first. Sorry you're having trouble, I know the excitement of getting new camera toys and wanting to play.
03-21-2014 04:48 PM
I had the same thing happen. I unplugged the charger and took the battery out. I placed in back into the charger plugged it in and everything worked just fine.
03-22-2014 11:12 AM
If the battery has been sitting on the shelf for a while, this can happen. Unplug it, wait a minute, plug it back in.
I have had batteries that I had to do this to once or twice, but once they started charging they were fine and never had another problem again.
Also, batteries don't last forever... I think of them like tires on my car. They don't wear much when I drive the car, but they do *technically* wear and at some point will need to be replaced. Heavily used batteries may only get a couple of years worth of use. Sparingly used batteries may get a few more years worth of use. Even batteries that are never used at all will eventually go bad... the technology isn't stable enough for a battery to last forever and just sitting on the shelf degrades them.
04-03-2014 05:17 PM
