11-20-2015 07:50 PM
11-20-2015 08:59 PM
Sounds like it might be stuck and camera spring can't pop it up. Try using a thin bladed knife and see if you can carefully pry it up.
11-20-2015 10:21 PM
Thanks, One other suggestion was to pry it open and then used compressed air to clean out the spring area. Believe it or not, it now opens.
11-21-2015 11:13 AM
It's just a spring latch that normally wants to pop open - save for a catch-hook that holds it down. The "clicking noise" is the servo retracting the catch hook so that the spring will pop it up (clearly that was working because you heard the noise).
If the hinge gets gunked up then the spring is not overcoming whatever is jamming it.
Incidentally, don't "oil" it because the oil would merely attract even more dust. We usually suggest just a drop of denatured alcohol to help dissolve anything -- because the alcohol will evaporate on its own.
11-21-2015 03:24 PM
Thanks, I just tried blowinig it out with compressed air and that has seemed to fix the poroblem for now. I may go ahead and put a drop of alchol in there as a premptive strike.
11-21-2015 04:54 PM - edited 11-21-2015 04:59 PM
@jrn wrote:Thanks, I just tried blowinig it out with compressed air and that has seemed to fix the poroblem for now. I may go ahead and put a drop of alchol in there as a premptive strike.
In the future avoid using compressed air anywhere near your camera. It can blow dust into parts you wouldn't want it, and embed dirt in some parts permanently damagingly them.
There should be something similar to this in your manual.
Stick with a bulb blower like a Rocket Blower in the future.
