08-08-2018 04:13 PM
HI ,
when I take a picture of the moon or bright object at night get a ghost or reflection of subject, Have cleaned lenses ,occurs with any lense. Have cleaned inside camera also . Is something out of alingment?
Thanks
08-08-2018 04:21 PM
Hello!
To have a better understanding of your issue, please let everyone know your camera model, and any lenses you are using.
If this is a time-sensitive matter, our US-based technical support team is standing by, ready to help via Email at http://Canon.us/SupportCF
Thanks!
08-08-2018 04:39 PM
Are you using a filter (such as a clear glass or a UV filter for protection) on your lens? If so, please remove the filter and try the lens again.
Filters are the most common explanation for "ghosting" and reflections when photographing brightly lit objects (relative to anything else in the frame.)
08-08-2018 05:00 PM
I am using a UV filter will try that ..thanks
EOS REBEL XT
08-08-2018 05:03 PM
EOS REBEL XT all lenses are Canon
08-08-2018 07:29 PM
@randyferron wrote:EOS REBEL XT all lenses are Canon
Are you using “digital” lenses, or older lenses released for film cameras?
08-08-2018 07:33 PM
The one I use is Canon EFS 55-250mm image stabilizer.
regards
08-08-2018 07:48 PM
@randyferron wrote:The one I use is Canon EFS 55-250mm image stabilizer.
regards
That lens should be okay, like any EFS lens. Do a reset to factory defaults on the camera. Not sure if that model can take a double exposure, or not. That could explain a “ghost” image.
08-09-2018 08:39 AM
You might try it with the IS off, especially if you are on a tripod.
08-09-2018 11:47 AM
"... bright object at night get a ghost or reflection of subject,..."
Not just remove but discard that filter. If it is screwing up your Moon shots, it is doing the same to all your shots. If you feel the need for a filter get a top quality one such as the B+W brand. IMHO, the EF-S 55-250mm f/4-5.6 IS STM lens may not be a good candidate for a HQ filter. That's up to you, though. Also when you shoot the Moon turn off AF and do the focusing yourself.
Second, depending on what you want or are expecting, 250mm doesn't have enough FL for a Moon shot. It will be prety small in the frame.
