02-27-2014 07:47 AM
When using the largest media card your camera will accept, is there also a maximum read/write rate ? if so, how can you know when it is not in the manual?
03-07-2014 05:34 PM
Charmdragon,
The maximum read write speeds are not published specifications. We apologize for any inconvenience that this may cause you.
02-27-2014 08:44 AM
Hi Charmdragon!
So that the Community can help you better, we will need to know exactly what equipment you're using. Any other details you'd like to give will only help the Community better understand your issue.
Thanks!
02-27-2014 09:10 AM
My EOS-1D Mark II N will support CF cards up to 16GB and SDHC cards up to 8GB. Yet, it does not support the UDMA (high speed) rated cards. Thus my maximums are a non UDMA CF card, and a standard speed SDHC card. I cannot find any reference to a) what is 'standard speed' for an SDHC card or b) if there is a limit to the read/write speed of the camera.
03-07-2014 05:34 PM
Charmdragon,
03-08-2014 09:37 AM - edited 03-08-2014 09:38 AM
The super large CF and SD cards are not desirable. Before I retired I shot professionally and can tell yoiu, especially on a
1D Mk II n, you don't want or need them. Actually 4 GB cards are great. The reason is, cards fail and when you have a large card you lose large!
It is far better to have several smaller cards and change them as needed.
The 1D Mk II n is a fantastic all professional camera. It is one of the best Canon has made. It is possibile to write RAW to the CF card and jpegs to the SD card.
As to write speeds, the 1 D Mk II n, will be ready for the next shot way before you are. ![]()
Great camera! You can earn a living with that camera.
