02-05-2020 04:20 PM
I just got a M6 Mark II and a mount adapter for the EF-EFS lens so that I can use my current lenses from my T2i. I am having problems with my Rokinon 14mm wide angle since it doesn't have electronics, fully manual. When I press the shutter release to take a picture, nothing happens. I have the camera set to manual focus and I have Manual mode selected, but is there another setting that I need to check?
My other Canon and Tamron lenses that have electronics work fine.
02-05-2020 04:42 PM
With that lens, you may need to go into your custom function section of the menu where there is a setting to release the shutter without lens because it may not recognize that lens as being present.
Rodger
02-05-2020 04:42 PM
Rodger
02-05-2020 04:45 PM
Rodger,
Thank you, that was the magic piece of information that I needed. The len works great now.
William
02-05-2020 04:47 PM
William,
Glad it worked, have fun making some great images!
Rodger
10-18-2021 12:05 PM
I enable the Release Shutter w/o lens on my Canon EOS Mark II M6 Mirrorless camera so I can use it with my Celestron Scope for birdwatching photos but once mounted on my Celestron, it is still not allowing me to take photos. Is there another step? I tried it both with Auto Focus and Manual Focus and I tried several of the photo settings but it is still not taking a photo. Any suggestions? Thank you Laurie Turns
10-18-2021 12:14 PM
10-18-2021 12:16 PM
10-18-2021 12:17 PM
Thanks so much but when I set it to Manual Focus and then I selected the Manual Setting as well, it worked! I think I am all set but will need to find a tri pod sturdy and tall enough (yet light enough) to take on my bird watching trip to Ecuador coming up. The tri pod I have is not going to be sturdy enough for my Celestron Scope and camera combination.
