07-28-2018 01:49 PM - edited 07-28-2018 01:51 PM
Hello,
I am trying to use the M50 for Youtube live streams and I have it attached via HDMI to my Macbook. It's connected to aux power (DC outlet) and I have Auto Power Off disabled, Viewfinder Off disabled and Display Off set to the max of 30min. The M50 will not stay on past 30 minutes. It still turns itself off after 30min has elapsed.
Is there a way around this?
Thank you.
04-10-2020 08:39 AM
Manual Focus* Corrected 🙂
04-11-2020 11:46 AM - edited 04-11-2020 10:39 PM
@Ray-uk wrote:Otherwise known as Oxymoron mode
As defined by the Department Of Redundancy Department.
04-11-2020 02:38 AM
I believe you are correct, do you know where those settings are in EOS Utility?
I'm streaming using OBS Window Capture on the EOS Utility and that works great. I use a USB mic for audio but just want to verify it won't auto turn off after 30 minutes. I just need to know where that setting is. Please help! Thanks
05-28-2020 09:14 PM
What about if I am 15-20 feet from the camera with the computer? Running HDMI that long is not a huge deal, but USB? I don't believe that's feasible...
04-11-2020 12:17 PM
04-11-2020 02:16 PM
@walstonbball wrote:
Do you know how to keep it from turning off? Can’t figure it out in EOS.
Turn it offf in the camera before you connect.
04-11-2020 02:32 PM
04-11-2020 03:02 PM
So in the camera itself? Where in settings is that? Thanks!
It is in the User Manual.
04-11-2020 05:44 PM
04-14-2020 11:48 PM
I can’t find it?? What section or page number. Thanks!
Make sure you're using the full-length user manual. You may have to download it from the Canon site. The paper manual is often an abbreviated version.
