06-01-2021 10:58 PM
Can I connect via WiFi or Bluetooth with an HDMI cable connected? I know you cannot with USB connected, but the manual is not clear concerning HDMI.
06-05-2021 07:16 PM
06-02-2021 01:08 AM
I would assume that if whatever it is you're looking to do is not specifically spelled out in the User Manual, then you cannot do it.
06-02-2021 09:16 AM
Since HDMI is just a mirror of the LCD, it should be fine.
06-05-2021 06:28 PM
@kvbarkley wrote:Since HDMI is just a mirror of the LCD, it should be fine.
Which is exactly why it probably wouldn't work.
The HDMI port disables the LCD in most cameras. Connecting via USB reproduces the rear display, but it does not work when an HDMI cable was connected. The Bluetooth connection seems to redirect the rear display signal, too.
06-05-2021 07:16 PM
