04-19-2023 08:07 PM
I know there isn't an update available, but I'd like to flash the firmware back to 1.0 on my EOS M200. I have reason to believe a modified version of the firmware was installed for malicious purposes using the USB connection to my computer as an attack vector. If that's the case would flashing fw be sure to neutralize the threat, or might it persist like a hacked motherboard BIOS?
04-20-2023 01:47 AM - edited 04-20-2023 01:50 AM
Because Canon never published a firmware update for M200 it is unlikely that a modified firmware has been installed in your camera.
No success for Magic Lantern to reverse engineer M200 either.
For some older camera models from Canon, for example M100, there was a security issue via WiFi. An intruder controlling the WiFi network could hijack a camera. Canon solved it with a firmware update.
04-20-2023 08:41 AM - edited 04-20-2023 08:45 AM
Greetings ,
Peter is correct. There were no known incidents. Canon patched this vulnerability because the potential for it existed, not because it happened. The M100 was patched. The M200 probably already included the fix. Hence no update.
You can read about it here:
No incidents were reported, a security firm merely demonstrated it could. Rest assured you are fine.
04-20-2023 10:53 AM
and yet I have reason to believe.
Is there a teardown guide somewhere? Maybe this camera has different internals. Can the wifi/bluetooth be removed?
Other possibilities include someone at canon being responsible, or their firmware code being stolen and changed for malicious purposes, or something like a hak5 om.g chip in the usb cable or in the camera between the usb port and the board.
04-20-2023 12:45 PM
There is a third-party app to turn off things and reset the camera to factory mode, but that is not something for this forum so you will have to search yourself.
04-20-2023 05:08 PM - edited 04-21-2023 02:13 AM
@EvangelionAdams wrote:and yet I have reason to believe.
You're welcome to believe what you like. I'm not going to try to convince you otherwise.
Your camera is not on the list of affected models. This is a fact.
"Other possibilities include someone at canon being responsible."
Do you have any evidence of this? If not, I think that is reaching.
Tear down and schematics is likely available at USCamera dot com. I would recommend against trying to forcibly remove the camera's wi-fi or bluetooth capability. It might not work after this type of surgical procedure. Maybe you could choose a model that doesn't have these features if you are concerned?
Or, you could accept that Canon who has demonstrated a sincere interest in the past for its customers well being would take steps in the event they were needed.
I hope you enjoy your camera, I'm sure that's why you purchased it.
