11-28-2015 01:02 AM
Will this lens go on my T3i?Canon EF 24-105mm f/4 L IS USM Lens (white box) for Canon EOS Digital
11-28-2015 07:01 AM
Yes, it will work.
11-28-2015 10:00 AM
Not only will it work, it is the 'best buy' in a Canon full on pro level "L" lens! ![]()
11-29-2015 12:47 PM
Your Canon EOS Rebel T3i can use any Canon EOS lens in the lineup.. except a couple of the new lenses that were designed exclusively for use on the Canon "mirrorless" bodies. Those dedciated lenses for mirrorless bodies will have the letters "EF-M" in the name of the lens.
That means you can use any Canon EOS EF, EF-S, TS-E, or MP-E lens in the Canon EOS lens lineup (past, present, or future!)
You cannot use the Canon EOS EF-M lenses (those only work with EOS-M series bodies.)
11-29-2015 08:10 PM
Thank you! I am so undecided in what to purchase. I have 3 stand lenses and never get the shots I'm after so I'm trying to purchase a lense that is amazing and overall the best investment, otherwise I'm just gonna give up trying to take all the time with just ok photography. Is there any other lens recommended for action, portrait, walk around lens????
11-29-2015 08:13 PM
What are the three lenses you have?
11-29-2015 08:41 PM
Canon 50 mm standard Ef 1:1.8
canon zoom 75-300 EF 75-300mm 1:4-5.6. 111 USM
18-55 canon efs (broke auto focus)
11-29-2015 11:11 PM
@Gerilynn wrote:Thank you! I am so undecided in what to purchase. I have 3 stand lenses and never get the shots I'm after so I'm trying to purchase a lense that is amazing and overall the best investment, otherwise I'm just gonna give up trying to take all the time with just ok photography. Is there any other lens recommended for action, portrait, walk around lens????
The best walking around lens on a T3i is the 17-55mm f/2.8 IS. The 24-105mm f/4L has more range and may be a bit better optically, but it lacks wide-angle capability and the extra stop of speed. The 24-105 is (at least arguably) the best walker on a full-frame camera, and a FF camera won't even accept the 17-55. So if you see a 5D or 6D in your future, you may want to buy the 24-105 now.
11-30-2015 12:01 AM
Ok, u have me thinking, what about this lens:
Canon EF-S 15-85 mm f/3.5-5.6 IS USM Lens
It has the extra zoom I'm looking for,
11-30-2015 09:53 AM - edited 11-30-2015 09:57 AM
Bob from Boston is referring to the Canon EF-S 17-55mm f/2.8 IS USM Lens. Since your kit lens of this focal length is broken, this is the lens to replace it with.
It is not going to be a cure all, neither would the EF 24-105mm F4L IS. Is it, or are both, capable of taking great photos? Absolutely.
If you could post some samples of what your photography lacks, it would be much helpful. At least, more of what goal do you have for yourself.
