02-27-2013 12:59 AM
I received the Rebel t4i for Christmas. It's been working great until today. The lcd screen no longer shows any information. If I press any of the setting buttons (ISO, etc), nothing shows up. It worked fine this past weekend.
09-28-2015 11:10 PM
Hello, I have just inserted the eyecup again until to hear a clip sound. Probably it moved a little bit up the last time I used it.
09-29-2015 12:50 AM
I have carefully compared the structure of my Rebel T3i camera with the manual. You all are describing something that looks like this:
http://www.manualslib.com/manual/454362/Canon-Eos-Rebel-Sl1-18-55mm-Is-Stm-Kit.html?page=15#manual
My camera does not look like that. There is simply nothing like the "Display-off sensor (p.42)" on my camera. Nevertheless, I removed the rubber eye cup and the screen did not come to life.
If anyone knows of a second suggestion, please speak up. Otherwise I am stuck for an expensive repair that may cost more than the original camera.
03-22-2016 05:53 PM
YAAAASS this saved me thank you!!!
06-28-2016 12:36 PM
I've been traveling in Spain with my new Canon T5 and after three weeks of taking photos. Today the screen, too, has decided to go blank. Suggestions?
06-28-2016 02:16 PM
Blank screen? If you cannot call up menus or saved images, then you may likely have an LCD screen failure. Make sure that the camera is "awake", though. Press the shutter to wake up the AF and exposure systems, then press "Q" or "Menu", or the playback arrow key.
The solution presented in this thread would not apply to a T5 because it doesn't include the feature that this thread addresses.
06-28-2016 02:25 PM
09-05-2016 12:41 PM
Hello Scott,
I have the same issue of display gone blank in LCD Screen.. I tried cleaning all the sensors... But when I move the video option, the display working.. but on any of the photo option. Can you please help in resolving this.
THanks for your help in advance
Best wishes
Raghunathan
@ScottyP wrote:Will it work under any circumstances?
Will it work (show moving pictures) in live view shooting movies?
If you press "MENU" do you see anything?
If you hit the "PLAY" button can you view photos you have taken?
01-28-2017 06:24 PM
For me it was the rubber cup issue. I would have never found this. Thankks!!
01-28-2017 07:43 PM
Thanks for your post. For me the rubber eye piece was bumped up a bit doing just what you said. I never whould have figured this one out.
Thanks Bill
02-01-2017 07:10 AM
