10-24-2018 01:50 PM
Hello people,
I'm new here and I hopa you can help me. I have a Canon 6D , I normally shoot on Raw but yesterday I did it on jpg format M quality , when I downloaded them they became about 900 kb ! None is over 1.3 MG . I have no idea what could 've happended. I reset the camera.
Thank you very much !
10-25-2018 09:29 AM
Oh and don't confuse the image size in MPixels with the file size.
Other than the wierdness that the M and S are the same pixel size your numbers are consistent with a coarse quality.
10-26-2018 09:41 AM
Thank you very much ! your guide is very clear, I guess I got confused with the pixels size thinking that it was the file size.
Thanks again for your time !
10-24-2018 02:26 PM
I think the 6D creates 8-9 MB files at that resolution and format. You can check the file size in the camera when you review the images saved on the memory card.
Where did you save the downloaded files? Some software and devices can automatically downscale the size of JPEG files.
10-24-2018 04:00 PM
Yes ! but for some reason stop doing it. The maxime size I get is 2 MG on L quality .
I did it already and it shows the problem on the display
On my desktop ( IMac OS High sierra ) . I've tried in different computers and nothing changes.
Thank you sooo much !! I have no idea what's going on..
10-24-2018 04:58 PM
If you have reset the camera, and it still reports the small file size when you playback images, then the problem is with the camera.
I should point out that I had Apple products in mind when I said some software and devices change the file size. What application are you using to download the files to your desktop?
I suggest that you take some more photos, but do not download them. Check the file sizes in the camera before you download them, and check what camera shows again after you download them.
10-24-2018 06:03 PM
What is the actual resolution of the files in pixels? JPEGs can vary a lot depending on ISO and image content. If you are taking a picture of a blank wall, or a high-key image of some jewelry, the files might be very small.
(You can demonstrate for yourself the relationship between ISO and file size by looking at the number of JPEGS you can store on the card while changing the ISO).
10-25-2018 08:54 AM
Hello!
I took 3 photos ( ISO 400 ) and these are the results:
Jpg L quality 3.3 Mb - 5472x3648 px
Jpg M quality 1.5 Mg - 3648 x 2432 px
Jpg S quality 582 Kb - 3648 x 2432 px
Any idea? Thank you so much !
10-25-2018 09:21 AM
L, Mand S are *sizes* not quality. Are you using coarse or fine quality?
10-25-2018 09:29 AM
10-25-2018 11:29 AM
"Any idea? Thank you so much !"
Nothing is wrong. It is working correctly. You are looking for a problem that isn't there.
10-26-2018 09:34 AM
Yes ! you're absolutely right, my mistake. I'm using fine quality.
thank you !!
