Is the Cannon T-3i a UHS host device?
cwmdreb
Can the T-3i use the new larger capacity memory cards with a 3 UHS speed class to it's full potential?
2 REPLIES 2
Skirball
I don't think so, I'd guess it's "only" UHS-1. Even then, I don't think it's bus is even fast enough to fully take advantage of those speeds; the 5d3 isn't.  UHS-3 is pretty new, aimed at 4k video recording.
That said, I doubt that you would see much, if any, of a performance difference if it did. Unless you're holding down continuous shots forlong periods (30+ frames, in RAW) it won't make a difference.  Even then, it'll be the difference of getting 29 shots in a set period of time versus 30.
Thanks very much!!! That is what I suspected, so don't waste the money on the latest and greatest new memory card. Tom
