IDxII shortfalls.
Edward
Enthusiast
The lack of Wi-Fi, HDR capability, a full touch LCD with automatic brightness control (as in the 5D series), short battery life and failure to reduce size and weight are disappointing. The card slots arrangement is strange, both cards fronts should have faced in the same direction when inserting and the Slot 1 selected for the CFast card instead of the old Compact Flash. The improvements in image quality and autofocus performance in my opinion, are minimal compared to the previous model, not to mention the competition. And the dual battery charger; why not a charger for a single battery or having an option for buying one? In these days of flying, any reduction in size and weight makes the gear easy to carry and accepted as a carry-on v.s. a check-in---international airlines are limiting carry-ons to just one not to exceed to 9 kilos.
Ergonomically the camera's undersized control buttons make it difficult to use with gloves in cold weather, and the failure to provided illuminated ones make them hard to see at nighttime (Yes Canon, there is nightime photography). When using long telephotos handheld or on a tripod, the 3 control buttons on the top left of the camera are hard to operate and should have been positioned as in the 5D series or 7DII for ease of use and conformity of design. This change would also have resulted in a cleaner top deck look and reduction in control buttons for the 1DxII. The remote control terminal at the bottom of the handgrip should have been moved to the front left as in the current 5DIV, its present location interferes when handholding the 1DxII when devices are attached.
Most camera manufacturers release professional gear having the best technologies that then trickles down into cheaper models; Canon has this reversed. As an example, touch screen has now moved up to the 5DIV; it could have been incorporated into the 1DxII. T­his stingy marketing strategy of small incremental improvements causes Canon sales; the reason why I am not purchasing a 5DIV and may skip the 1DxIII too.
35 REPLIES 35
TTMartin
You are right it is worthless. I'll give you $300 for it shipped so you don't have to deal with those short comings.
 I would not like to sell it to you since it is now a Canon for repairs. Taking $300 from U would not be ethical.
There is always the Nikon D5.  It is a fantastic camera.  Sounds like you need one.
Most of the things you have asked for on the 1D Mk II, I don't want.  Neither here nor there but we are out there.  The only change I would like is the price.
EOS 1DX and many lenses.
jrhoffman75
"Most camera manufacturers release professional gear having the best technologies that then trickles down into cheaper models; Canon has this reversed. As an example, touch screen has now moved up to the 5DIV; it could have been incorporated into the 1DxII. T­his stingy marketing strategy of small incremental improvements causes Canon sales; the reason why I am not purchasing a 5DIV and may skip the 1DxIII too"
Perhaps Canon's strategy is to release those features NOT in the pro level machine first to get it debugged in the field. Pros who depend on the tool for their living might not want to be the first adopters.
You're telling us that you bought a $6000 camera without researching its features (or lack thereof) any better than that? Did you not make a requirements list and check it against the specs? The only thing I can think of to tell you is that if I'd done that, I sure wouldn't admit it in this forum.  Smiley Wink
Bob
AH!  I see said the blind man.  I hope it works out for the best.  What happened to yours?
Most of the things you have asked for on the 1D Mk II, I don't want.  Neither here not there but we are out there.  The only change I would like is the price.
I am no professional, but I am forced to agree with you.  Most of the list is bells and whistles, with very little to do with producing high quality images.  Adding bellls and whistles, means additional programming.  You may not have the programming memory space for such things.  I think like an engineer because I am an engineer.
I would think that a touch screen on a professional camera would be undesired.  What happens when it is used in bad weather, and drops of water collect on on the display ...  and drops start dribbling down the screen?  I don't think the camera would like rain drops of water striking the touch sensitive screen.  I am certain that would not like it.
How do you wipe off the water?  I suppose that you could blank the screen and then wipe it, but it would be better if you could simply disable the touch sensitivity, altogether.  If you can disable it, then why even include it?
It is in my thoughts...
I am telling you that Canon can build a better camera and due to marketing strategies is shortchanging its customers.  Not my first one; just realized the scheme.
