07-30-2016 04:38 PM
I have a Canon Rebel t5i. Out of the blue, the screen stopped displaying my pictures after I took a picture. When I press the menu button, the screen works fine, as well as when I press the play button, but it used to show the pictures as soon as I snapped one. I have checked the settings and Image review is set to 4 seconds. I am not sure how to fix this problem. Can anyone help me?
07-30-2016 05:09 PM
Try resetting the camera. If you are correct about the playback delay, try changing it, too.
07-30-2016 05:19 PM
07-30-2016 05:32 PM
@jojotj11 wrote:
Thank you so much for your reply! I am fairly new to this camera. I am not sure how to reset the camera. Also, I have changed the playback delay to off, didn't work, then I changed it to 2 seconds, 4 seconds... So on. Nothing has made a difference. I just like seeing the picture I take right after I take it.
Do not press any buttons after you take a picture, and the image should appear. You can clear the camera in the menus.
IF you do not have a copy of the instruction manual, then you can download it at the following link. Enter your model number.
https://www.usa.canon.com/internet/portal/us/home/support
07-30-2016 05:33 PM
BTW, are you using the LCD screen to take pictures, Live View mode? If so, your images will not appear after you take them.
07-30-2016 06:37 PM
08-02-2016 05:05 PM
which button are you using to review your shot right after you take it? Also, what kind of sd card are you using? (the micro w/ adapter don't work) In your manual it will tell you which ones work best. When all else fails, reset! lol I am new too, and I have found the best way to learn is to get thru the hurdles, but keep going. Try not to get overwhelmed. One bite at a time, pretty soon you have eaten an elephant. Everyone on this site is so helpful when you get stuck or need some advice. Just a word, stick to photography issues or they will censor every word. So did you figure out what was wrong or get it fixed at least?
08-03-2016 10:48 AM
08-03-2016 10:57 AM
On my T6S, after you hit the menu button, it is in the first "camera" menu under "Image Review". You can set it to off, or some number of seconds and "hold".
08-03-2016 11:39 AM
