How to lower exposure while doing long exposure shots.
hanitakashi
So I’m doing some night photography and I want some nice streaks of the head lights and tails lights of cars. So my shutter speed has to be long. However, my photo has too much exposure in them. Changing the shutter speed would fix that but I can’t cuz I need it to be long. My iso is at 100 (lowest setting) and my aperture is at f 3 (lowest setting). Any help would be appreciated.
4 REPLIES 4
larryc43230
Enthusiast
I'm not sure what you mean by "f 3 (lowest setting)"; I'm assuming that's a typo. Pretty much any aperture with a higher number (say f/16) would give you better results.
You might want to look into getting a neutral density (ND) filter. One of these (they come in several strengths) will cut down the light getting into the camera.
Larry
rs-eos
Assuming you’re at the lowest ISO value, you only have two options: Narrow the aperture; Use a neutral density (ND) filter.
I would recommend either a 3-stop or 6-stop ND. Though first narrow your aperture by that amount to see if that will have the desired outcome.
Note though that if using a 6-stop or stronger ND filter, your camera may have difficulty focusing. You may thus need to first focus without the filter attached, set to manual focus to lock focus, then attach the filter (this would require working on a tripod)
Ricky
Camera: EOS 5D IV, EF 50mm f/1.2L, EF 135mm f/2L
Moderator
Moderator
Thanks for joining the conversation, hanitakashi!
So that the Community can help you better, we need to know exactly which Canon camera model you're using. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
Anonymous
Not applicable
Just restating what others have said, a smaller f-stop number means more light (larger aperture opening) while a larger f-stop number means less light (smaller aperture opening). So you would want a larger f-stop number to let in less light in your case.
Avatar
