08-27-2013 12:35 PM
Visited the camera shop over this past weekend. The person helping me turned the Histogram on so after a shot is taken, this is displayed. How do I turn this setting off to display the shot I have just taken? The manual is no help in solving this problem.
Artvein9
09-10-2017 02:17 AM
And did they also tell you how to find some good manners to show to total strangers who were only trying to help you?
09-11-2017 01:17 AM
At the bottom, below the wheel on the back is a triangle. That is to view your last shot. View your last shot with this button then press "DISP" to cycle through the various photo analysis (histograms).
I understand your frustration. That has happened to me a couple of times and I've had to go through the whole remember what button to hit to turn it off. Also, as I recall, the T3 has the "DISP" button right where your thumb rests while holding the camera.
Good luck.
09-11-2017 09:50 AM
01-01-2019 09:50 AM
Thanks for the info. Worked well. Happy New Year.
01-10-2019 11:47 AM
Thank you Tricia1! I had the same issue and that was a quick and easy fix. 🙂
01-13-2019 03:29 PM
Easily found on page 70 of your manual
03-19-2019 08:41 PM
10-19-2019 01:21 PM
I have a Canon Powershot ELP 110 HP. Had it for years. I was trying to turn off the HIsogram and this is what worked for me.
Turn on camera
Click the arrow button to play your pictures.
Click on Disp
Click on Disp again
This will show you the whole image on the screen.
Then to test it,
Turn off Camera
Turn of Camera
Go to Play and it should have retained your setting.
Thanks,
Natalie Nave
10-19-2019 01:32 PM
Don't know if anyone is still looking for the answer but it is:
Turn the camera on
Press the arrow or play button
Press DISP
Press DISP again
Turn the camera off and back on to see that it kept your settings
Should have a full screen picture now.
Thanks,
Natalie Nave
04-22-2020 07:26 PM
