01-10-2017 08:57 AM
Canon 6D. I've been shooting in jpeg for a long time. I'm trying to start using Raw some. When I select to shoot in Raw and Jpeg together (Raw/Ljpeg), it seems I'm only getting pics in Raw. All pics suffix are CR2. What am I doing wrong?
01-12-2017 09:46 PM
I don't see this option in Lightroom. I just took one pic with camera and then checked the SD card. Only one pic on SD card. Double checked quality setting and it is RAW + L (jpeg).
01-12-2017 09:48 PM
Mine is set at RAW + L. Just took one pic and checked the SD card. Only one pic on the SD card.
01-12-2017 09:54 PM
Verified the setting. Just took one pic a few minutes ago. Checked SD card and there is only one pic. Import pics to LR by plugging SD card into laptop.
01-12-2017 10:09 PM
When you say you checked the SD card did you open it as a disk drive in Windows Explorer?
01-20-2017 11:10 PM
I just changed my setting to RAW/ L (jpeg) and took one pic. Loaded the one pic that is on the SD card into Lightroom. In Lightroom there is only one pic and it has a suffix of CR2.
Just tried something different......Loaded same pic from the SD card into Picasa. In Picasa there are two pics. One Raw and one Jpeg. There must be a setting in Lightroom that I need to change.
01-20-2017 11:37 PM
Looks like there must be a setting I need to change in Lightroom. Just took one shot and plugged SD card into Laptop. Viewing the SD card both images are there, RAW and Jpeg. Also loaded the one image into Picasa and it has both images. Load it into Lightroom and there is only one image, the Raw pic.
01-21-2017 07:02 AM
01-24-2017 09:34 PM
I appreciate your reply. I can't find this Preference screen. I'm using Lightroom CC 2015. Thanks for your help.
01-24-2017 10:02 PM
01-25-2017 07:44 PM
Thanks!!!!!!!!! I had looked everywhere earlier and missed Preferences under Edit. I checked that box and now have two images each. One Raw and one Jpeg. Thanks again.
