12-14-2015 09:07 PM
When I try to use open remote camera control I get a message saying "out of memory" This is the first time I have tried this. Any ideas?
12-14-2015 09:38 PM
We need more info. What operating system? What software?
12-15-2015 12:11 AM
Are you using Canon EOS Utility or are you using something else to control the camera? Also, how much memory does your computer have?
12-15-2015 05:29 PM
MAC OSX Yosemite and EOS Utility
12-15-2015 05:30 PM
EOS Utility and Mac Book Pro with 8GB memory
12-15-2015 06:43 PM
Lets try this.
1. be sure you are using a Canon USB cable or one that you know is a data cable
2. plug in camera and turn on
3. open Image Capture in Applications folder
4. is the camera recognized? If not, does the computer recognize a card reader or other devices plugged into a USB port? If not, see here: http://www.pntbrother.com/macbook-pro-usb-ports-not-working-reading-solution/
5. in the Applications folder you should have a folder labeled EOS Utility
6. in that folder you should have an application EOS Utility and a folder EU2
7. open the EU2 folder and run EOS Utility 2. That will give you the windows to control the camera via EU.
Report back with any results.
12-16-2015 01:47 PM
Steps 1,2, and 3 are good.
Step 4 The camera is not recognized, but other devices are. The camera is recognized in Lightroom 3.
Step 5 In application folder I have a Canon Utility folder which contains EOS Utility, Image Browser etc.
Step 6 I have no EU2 folder, but I do have WFT E1 through E5 folder which will not open. I get a pop up that says "Utility quit
unexpectedly."
I can open EOS Utility and Camera Control, but when I open Camera Settings/Remote Shooting I get a pop up that says "Out of Memory." I have an empty 8GB card in the camera.
Thank you for your interest and help in this as I am completely stumped.
Ray
12-16-2015 02:00 PM
Try this.
http://community.usa.canon.com/t5/EOS/eos-utility-error-out-of-memory/td-p/14131
