01-26-2017 07:39 PM
I recently was gifted a Rebel T6. I have 2 cables from an old Olympus film camera that keep the shutter opened. Can these be used with the Rebel T6? If not, what would I use to do this?
Thanks,
T3ijbp
01-27-2017 10:54 AM
You need a Canon RS60-E3 or equivalent. This is a wired remote release that plugs into port on the left side of your camera. It's has a shutter button with a lock switch. You set the camera to 'bulb' mode and the camera will hold the shutter open for as long as the button is pressed on the RS60-E3.
There are some 3rd party equivalents that have timers on them (Canon doesn't have a model with a timer for your camera) so you can dial in a specific amount of time and often these also allow you to program it to take shots at periodic intervals (e.g. Take a shot once every 5 minutes for example). For this reason, these remote releases with timers are often called "intervalometers".
01-26-2017 08:11 PM - edited 01-26-2017 08:12 PM
The Bulb setting in TV will keep the shutter open as long as the shutter button is depressed. You can also get wired and wireless remote shutter releases. If your old cable shutter release uses a threaded end, it won't work. In any case, it has to be Canon compatible, which yours probably isn't anyway.
01-27-2017 10:54 AM
01-27-2017 11:12 AM
Canon does not make a timer that will plug in, but they *finally* make an adapter RA-E3 that will let you use a TC-80n on almost any camera.
01-27-2017 12:37 PM
Thanks for the info. This is now on my list of things to get.
