06-29-2026 11:15 AM
I recall from an earlier camera that getting these two to talk with each other is finicky, but happening again.
I have gone through the early steps of the process -- enabling WiFi, giving a nickname to the phone, opening WiFi on phone but the nickname of the phone does not show up on the phone (even after turning WiFi on an off). As well, when I try to simply hit "send photos to smartphone, it says no connection established.
What am I missing?
Thanks!
06-29-2026 01:38 PM - edited 06-29-2026 01:39 PM
The page apparently does not allow me to edit my post, so I'll append here.
I went through the entire process both on the app and with the camera, including regisrtering the camera, inserting the password into the a, etc. and it concluded on the phone by telling me the operation was complete. However, when I open up the app, it simply does not show any evidence that it is connected to the camera. ??
06-29-2026 01:46 PM
Please contact support at 1-800-OK-CANON (800-652-2666). They will help you get to know your camera.
06-29-2026 02:45 PM
The issue, I learned, is that my smartphone is set to auto default to my home WiFi network. Unlike the the past,apparently now I simple need to turn off thst shot connect instruction when using the camera directly either the smartphone
now I simply need to disable thst auto connect instruction for my home network when using the camera as a hot spot.
06-29-2026 05:47 PM - edited 06-29-2026 05:52 PM
I take that back -- still does not work. I have never had to actually shut off my home WiFi to get the camera and smartphone to connect, but even did that this time and it still does not connect. With my home WiFi disconnected, the app says "No WiFi connection." The nicknamed WiFi connection on the camera does not show up on available WiFi networks on my iPhone's WiFi settings menu.
07-01-2026 06:23 PM
Greetings Skip70,
I'm happy to hear that you have checked the auto connect function on your phone since that is one cause of why the connection between a camera and phone will not stay connected. Aside from the troubleshooting steps you have already performed, let's clear the wireless settings on the camera and try a new connection.
1. Turn the camera on and press the "Menu" button.
2. Navigate to the Tools tab which is labeled in yellow and has a symbol of a wrench.
3. Navigate to page 4 and then selection "Communication settings"
4. Please select "Built-in wireless settings"
5. Please select "Clear settings" then select "OK"
Then we would be able to set up the camera to connect to your device through Wi-Fi. I will include a link to the user guide for the wireless feature of the EOS 5D Mark IV where it will provide you steps on how to connect your device.
https://gdlp01.c-wss.com/gds/5/0300024975/01/eos5d-mk4-wff-im-en.pdf
In case the issue persists, then I would recommend for you to call our tech support department by phone. Sometimes things can be more efficiently resolved by discussing the issue in real time with a live agent. Technical support can be reached at 1-800-652-2666 between Monday and Friday from 9:00 am to 6:00 pm EST.
07-04-2026 03:43 PM - edited 07-04-2026 03:43 PM
NatalyaP
Thank you for the thorough reply. As it turns out, I did all that, several times. I did contact Canon Support directly by phone and was helped quite expertly and patiently by the rep, but even he could not get it to work after nearly an hour of troubleshooting..
I have some up with. bit of workaround, toggling WiFi and connected networks on and off, and grabbing the Canon connection when it happens to show up. I don't download photos very often to my phone, so that is not an issue, but I do not like the Live View viewing and shutter trigger feature so hope this WiFi issue sorts itself out.
