03-21-2015 11:07 PM
I understand that grain can come from multiple sources, but... I have a new 7D MKII. I like functionality and controls. What I have been having issues with is grain. My main question is this: Can a camera be defective in a way that grainy pictures are the result?
I changed for a 1D to the 7D, because as I get older the 1D got more uncomfortable to handle. (Probably my worse decision in a long time.) So I went from a professional to a proconsumer camera, got that. Also went from 1.3 to 1.6 multiplier sensor (or smaller sensor), got that.
I did a series of test shoots with my camera and my brother's 7D MKII shooting the same image at 100, 200, 400, 800, 1600, 3200, and 6400 ISOs. Cameras was on a Canon 600mm lens and then with same len and the 1.4 extender. Grain wasn't an issue.
As most problems with computer driven equipment it is probably operator error, but if there is a possibility it could be the hardware I need to know so I can get this resolved. This isn't my first camera, but it is beginning to feel that way.
Thank you. Fay
03-22-2015 11:14 AM
03-22-2015 09:53 PM
03-23-2015 09:23 AM - edited 03-23-2015 09:23 AM
"The confusion to me is that you find the second 7D better under the same conditions."
This is where I am losing it , also. Are absolutely sure both cameras and set up is exactly the same? You are not complaining about focus but extra grainyness so it is not micro-adjustment. Grain is really something that is not adjustable.
I will say again and can not stress this point enough, the photos from the 1D and from the 7D Mk II will never look the same.
They are not only two totally different designs, they are worlds apart. Nothing is comparable.
Can you make a side by side, one 7D vs the other 7D same subject and conditions and post the two shots here?
