03-19-2020 11:01 AM
03-27-2020 08:20 AM
IN the absence of a solution I have shipped the camera back to Canon to let them resolve it.
03-19-2020 11:15 AM - edited 03-19-2020 11:23 AM
1. Exactly which card are you using?
2. Which firmware and which file size if you check the unzipped file?
03-19-2020 12:02 PM
I am using aScandisk Ultra 64GB SD Card.
My 6D was running on 1.1.18 and I am attempting to update to Firmware 1.1.19
03-19-2020 12:13 PM - edited 03-19-2020 12:16 PM
In my opinion no need to update if you don't connect your camera to an unsecure WiFi access points. How often do you do that?
03-19-2020 12:19 PM
Peter
Thank you for that suggestion. However Iam at times connecting through "unsecure" wifi points, however even if I was not, this does not explain why Canon firmware will not upload into the Cano 6D. The FIR file has transferred to the SD Card and is showing on the root directory. Wht is not appening is the update from the card to the camera itself.
03-19-2020 12:30 PM - edited 03-19-2020 12:42 PM
1. Try 32GB card or smaller file size.
2. Low level format the card.
3. Check the file of when the file is extracted onto the card, 6D000119.FIR should be 21,346,096 bytes.
03-19-2020 01:04 PM
Make sure there is no other files on the SD card. The FW update is in the root folder? Yes, no?
D/L the FW update to a Windows computer. Extract it. Put that file on the SD card. Keep in mind if you screw this up your camera will turn into an expensive brick or paper weight! If there is no good reason to update the FW, don't do it.
03-19-2020 01:40 PM
Peter
This may be the reason for the failure...the downloaded 6D000119.FIR on my P.C.is showing as 20,846KB bytes.
I have tried downloading it twice now with same result???
@Peter wrote:1. Try 32GB card or smaller file size.
2. Low level format the card.3. Check the file of when the file is extracted onto the card, 6D000119.FIR should be 21,346,096 bytes.
03-19-2020 01:55 PM
03-19-2020 01:58 PM
I have also tried downloading from this site: https://in.canon/en/support/0400526302/1
where indeed it shows as supposed to be of the byte size you indicate. However when you download the zip file and extract it, it comes out at the size I have already indicated to you...couriouser and curiouser!
