EOS R6 Mark II Do you need exposure compensation if you'll be editing the photo?
Cantrell
Mentor
All,
Been reading about exposure compensation and using it in a EOS R6M2.It seems that using exposure compensation with the R6M2 is cumbersome. Do you need to be concern about exposure compensation if you are going to be editing the photo?
Interested in the groups thoughts on this subject.
Thank you in advance.
Reese
stevet1
Reese,
A couple of times, Waddizzle has suggested re-assigning your exposure compensation function to your SET button instead of a half-press of your shutter button for your R6 Mark II.
It looks like you can do this by going to your Custom Functions. It looks like it's in Custom Functions 3. Look for a setting called Customize Buttons..One of those should be to Customize Exposure.
From what I can gather, Exposure Compensation can be re-assigned to a handful of buttons: Your asterisk (*)  button, your SET button, etc.
A little circle means that it is enabled for that button. A dash means that it is not enabled for that button.
I personally like using the SET button, because you can use your thumb, while you turn the main wheel with your index finger.
Steve Thomas
31 REPLIES 31
kvbarkley
Not so much editing as the image source. A raw file has much more exposure latitude than a jpeg, so you don't need to be concerned with exposure compensation as much.
Generally, you only need exposure compensation when the automagic exposure is fooled. I have to use it when taking pictures of the moon or they come out very overexposed, or I just use manual exposure.
I am not sure what you mean by cumbersome, on my T6S it is *too* easy, I have to take care not to inadvertently turn it on.
kvbarkley,
Thank you for reply. With R6M2 you have to press the shutter button down half way then turn the Quick Control Dial 2. I have tried it, but seemed to be not a fluid motion when using the View Finder. Sorry I do not know how to explain it any better. It seems as if the hand that turning the QCD is interfering with looking through the viewfinder.
Reese
kvbarkley
You have to half press the shutter to wake up the exposure system so it is active. It seems to me, that like anything, a bit of practice should help. You might be able to move exposure compensation to a different dial, if you want.
MPBACK
Rising Star
Rising Star
Hello, I have never had an issue witth Canon's exposure compensation system.   In fact I switched camera systems way back because of the ease in using the large flat dial on the back of Canon bodies ot change exposure over  another well known brand at the time.  The other system you had to push an exposure comp button while setting shutter or aperture.  Using Canon's EC system becomes second nature .  Just keep working with it and it will be fine.
Waddizzle
“ Thank you for reply. With R6M2 you have to press the shutter button down half way then turn the Quick Control Dial 2. I have tried it, but seemed to be not a fluid motion when using the View Finder. Sorry I do not know how to explain it any better. It seems as if the hand that turning the QCD is interfering with looking through the viewfinder. “
Using AEC is pretty easy on advanced Canon cameras. The same setup works on all advanced models.
Use Custom Controls programming to configure the [Set] button for AEC.  It’s easy to use, too,m. Press [Set] while turning the Main Wheel.
If you shoot in M mode with ISO Auto, it’s a game changer.
kvbarkley,
Thank you for your response.
Reese
MPBACK,
Thank you for your reply.
Reese
Waddizzle,
Thank you for your response. I shoot Manual with Auto ISO. I will try and move to a different button. I just need to use more frequently.
Reese
Waddizzle wrote, "Use Custom Controls programming to configure the [Set] button for AEC.  It’s easy to use, too,m. Press [Set] while turning the Main Wheel."
That's the way it works on my T8i, but it comes that way by default. It's pretty easy, and if you are using Live View, you can instantly see it's effect before you take your shot.
I've been shooting in Av with Auto ISO recently, and it mostly only changes the shutter speed, sometimes in conjunction with ISO.
Steve Thomas
