12-21-2016 01:40 PM
I have an important shoot coming up, and my canon camera has an Err 20 that keeps popping up, pls help ASAP.!
12-21-2016 01:52 PM
@Skinnerwendell1 wrote:I have an important shoot coming up, and my canon camera has an Err 20 that keeps popping up, pls help ASAP.!
At any important photo shoot you should have a back up camera.
12-21-2016 01:53 PM
Hi, Skinnerwendell1!
Thanks for posting on our forum! This community is designed for your fellow Canon owners to help each other out with any problems they may encounter. If this is a time-sensitive matter, our US-based technical support team is standing by ready to help 24/7 via email at http://Canon.us/SupportCF or by phone at 1-800-OK-CANON (1-800-652-2666) weekdays between 8 AM and midnight ET (5 AM to 9 PM PT) and Saturdays from 10 AM to 8 PM (7 AM to 5 PM PT). We also encourage you to check out our Knowledge Base at that same link for answers to common questions.
Thanks and have a great day!
12-21-2016 02:00 PM
I'm 17 I was lucky to get this camera
12-21-2016 02:04 PM
@Skinnerwendell1 wrote:I'm 17 I was lucky to get this camera
Contact Canon U.S. Support will be best. Here is a link that explains error codes.
http://www.learn.usa.canon.com/resources/articles/2012/eos_error_msgs.shtml
Your "Err 20" suggests a mechanical failure.
12-21-2016 03:27 PM
I recognize "important" means different things to different people, but a rental might be a wise idea.
12-21-2016 11:41 PM
You can try to remove the lens and see if there is anything obvious - try a mirror lock-up for cleaning, too. Only do something if there is something really obvious.
12-22-2016 09:48 AM
@kvbarkley wrote:You can try to remove the lens and see if there is anything obvious - try a mirror lock-up for cleaning, too. Only do something if there is something really obvious.
Warning never actaully touch the mirror. It is very fragile and easy to scratch.
12-23-2016 10:59 AM
"...my canon camera has an Err 20 that keeps popping up.."
If it is truly an important event and you have err 20, you need to use a different camera. Do not trust this one. Err 20 usually means a trip to Canon service.
12-23-2016 11:53 AM
@ebiggs1 wrote:"...my canon camera has an Err 20 that keeps popping up.."
Trying to photograph an event with only one camera is a rookie mistake in any case. If it's outdoors or in a big room, you're sure to need both a normal lens and a telephoto, and you almost certainly won't have time to change lenses on the fly.
