12-24-2013 03:34 PM
12-24-2013 09:04 PM
Will any buttons activate the rear LCD screen (for any purpose)? e.g. can you press either the "Menu" button or the "Info" button and get a display?
On EOS DSLRs the "Info" button cycles through several choices to display on the rear LCD and one of the choices is to just have it off -- but that's because regular DSLRs have a viewfinder. The button simply keeps looping through the choices.
But on the EOS-M there is no viewfinder and I didn't think there was an option to disable the LCD when the camera is on.
12-24-2013 10:44 PM
12-24-2013 11:08 PM
Again... I've used a lot of cameras but I have not yet seen an EOS-M -- but this sounds susupiciously as if the LCD is not working (I did a quick scan of the manual -- knowing that an LCD can be turned off on an EOS DSLR but could NOT find any reference to turning it off for the EOS-M).
You may need to contact Canon for support.
12-28-2013 05:09 PM
07-20-2014 11:00 PM
Sorry to dig this up, but did you find a solution? This same exact issue happened to my eos-m today. Powers on, can still shoot, touch screen enabled but nothing shows up on the screen.
08-03-2014 11:49 AM
Hi uwaatw!
Thank you for the post.
When you press the MENU button or INFO button, does anything appear on the LCD then?
07-28-2017 03:52 AM
07-28-2017 04:23 PM
Hi, Eliquetric_04!
Have you tried the steps laid out by Mykolas in the post immediately above yours? Please follow his recommendations and let us know if you still need help!
07-30-2017 02:06 PM
hey, I don't have the camera anymore. Although I did fix it before selling it. I simply just purchased a replacement screen, and then took the camera apart and replaced the broken screen with the new. The new screen was fairly cheap.
