Eos Rebel T4i + 430EX flash = washed out pictures
WakkoWarner
I do eBay listings for someone.  When I am out of town, someone else needs to take pictures.  So, we purchased a Rebel T4i at a pawn shop (barely had 1,000 shutter activations on it).  It needed a flash, as the conditions in the warehouse are not always optimal for taking pictures.
So, we acquired a 430EX flash.  The problem is that no matter what position the flash is in, the pictures are always washed out.  We have a cheap Bower SFD35C flash that we were using with it (cost about $30).  It does an okay job, but doesn't light up the items enough (they are kind of dark, but never washed out like with the 430EX).
The camera that I personally use for taking the pictures is a Sony Alpha A65 with an HVL-F58AM flash.  I keep the flash angled one click backwards and the pictures always turn out fine.  Since I do not have experience with the Canon cameras, can anyone guide me as to setting up the camera and the flash to work together??  I am actually beginning to wonder if the flash is defective (it was purchased used), since once I take a picture, I can no longer adjust any settings on the flash until I turn it off and on again.
If anyone has any ideas or pointers, your input will be greatly appreciated.  Thanks in advance.
Canon EOS Rebel T4i
Canon EFS 55-250
21 REPLIES 21
There can be many causes for washed-out pictures. But one thing that will do it every time is using a flash set to TTL with a camera that's expecting E-TTL.
Bob
You have a reflective surface. You will need to get an extension cord to move the flash off camera or get two flashes at 45 degree angles. Or rig up a sheet as a soft box.
