10-09-2025 02:01 PM
I own the R5 and had been using the LP-E6NH battery with no problems. This battery is no longer in production, so I bought the LP-E6P. My shutter speed is usually 1600 or higher and the E6P battery couldn't keep up. Canon customer support had me change my Shutter Mode to Electronic. Now the battery works (I think) but I can't hear the shutter anymore to confirm. It will also make me crazy not counting the shutter clicks while shooting. Anybody else dealing with this? What is your work-around?
10-09-2025 02:59 PM
You might be out of luck there without Canon doing something in a update.
This
"The Mechanical Shutter produces a sound and is recommended for use with bright lenses. The Electronic First-Curtain Shutter also produces a sound but uses the second-curtain mechanical shutter. The Electronic Shutter is a silent mode that has no sound but can be more prone to rolling shutter effects".
Quoting the manual
10-09-2025 02:20 PM - edited 10-09-2025 02:27 PM
Check your firmware level this problem has been corrected in version 2.2.0 This update allows full use of the LP-E6P battery in the R5.
10-09-2025 02:37 PM
I don't think the R5 has a shuttersound in ES. Either use mechanical or EFCS. I upgraded to the R5II which does have a sound(not the reason but welcome).
And as Jkari stated the LP-E6P will be fully functional with the update.
10-09-2025 02:45 PM
Did that. Didn’t make a difference. 😞
10-09-2025 02:59 PM
This
Quoting the manual
10-09-2025 04:11 PM - edited 10-09-2025 04:15 PM
I have the latest update and it didn't make a difference with the shutter speed using the new battery. When I change it to Mechanical or EFCS the battery doesn't work efficiently.
I'd like a work around for Mechanical and shutter sound at the same time if possible.
10-09-2025 04:13 PM
While I accept the solution, I don't like it! lol I never realized how much I rely on the shutter sound while I work.
10-09-2025 04:37 PM - edited 10-09-2025 04:39 PM
I hate to here that. I will try the high shutter speed on my R5 with the different shutter methods using the E6P battery and see what happens. Are there any other unusual settings that I might need to know to test?
It might be Saturday before I can try it.
Any one else with an R5 having this problem?
10-09-2025 07:50 PM - edited 10-09-2025 07:54 PM
Oh, Thank you!!! When I'm shooting outdoor sports, I have the aperture as low as possible for a 100-500 lens, shutter speed 1600 and change the ISO as needed. With the kit battery at factory settings and current firmware, I could hear the shutter for each shot. The battery worked great. Once I popped in the E6P battery, the H would blink and the battery couldn't shoot at 1600 -- it was working slower. Canon customer service had me change the settings to Electric and the H stopped blinking, but I cannot hear the shutter and don't really know if it's shooting at 1600 or not.
Manual Mode: Eye tracker, servo, and H (not H+) are on.
Hopefully all of that info helps. I really appreciate your time on this!
10-10-2025 09:45 AM
Quick questions. What lens are you using and did you register the new battery with the camera to let it know you are using the E6P?
