07-09-2015 07:38 AM - edited 07-09-2015 07:45 AM
Running under W7, EOS Utility does not start anymore. Worked properly for a few monthes. Previously had some problems with wifi connection, corrected after unistalling and installing again. Now it wont start anymore (after a W7 update???) . Works fine in another computer running W7. Any suggestions?
07-09-2015 04:25 PM - edited 07-09-2015 05:29 PM
Thanks to all. The problem was not a W7 update, but AVG 2015 antivirus. Windows restore function was blocked by the antivirus. When antivirus was removed to allow Windows Restore to work probperly, EOS utility poped up and worked fine. Now I have to stop antivirus when using EOS utility. I will notify the AV maker to find a solution.
PS: With the nice help of AVG support, I have created some exceptions (files that are not checked by AVG) and included the EOS Utility in this exception list. It is now working OK!
07-09-2015 08:28 AM - edited 07-09-2015 08:30 AM
Have you tried a "system restore", using a restore point when it worked. You could also try uninstalling the windows update you think may have caused the problem.
07-09-2015 10:25 AM
"Any suggestions?"
Yes.
Uninstall it and reinstall it, agin.
Did you do any other upgrades or additions to the computer recently? Anything?
07-09-2015 10:31 AM
EOS utility is initiated when windows starts up. When the 'link' is broken or corrupted the utility can not 'sense' the presence of the connected camera.
Assuming that you have the original software discs, uninstall EOS Utility from the control panel, reboot, and re-install the program. Otherwise, download the EOS Digital Solution Disc Software from Canon, supply your camera's serial number (gleaned from a pictures exif) and reinstall. Once installed update to its latest version.
Hope this helps.
Paul
07-09-2015 05:39 PM
07-09-2015 07:38 PM - edited 07-10-2015 11:34 AM
@paulogcarvalho wrote:Thanks to all. The problem was not a W7 update, but AVG 2015 antivirus. Windows restore function was blocked by the antivirus.
Glad you're up and running.
I always...ALWAYS...disable my anti-virus program when using Windows system restore. I also create a full Windows OS Image backup every month after getting our monthly microsoft updates. That way if all else fails fixing any camera software issue, I can easily restore my OS (and camera software & programs) back to how it was before disaster hit. Sometimes windows system restore will fail for some reason or the other, most times from anti-virus protection being active. I cannot stress enough, the importance of an OS (operating system) Full image backup.
07-10-2015 06:08 AM - edited 07-10-2015 06:09 AM
My EOS Utility, both 2 and 3, works when I disable AVG. But exclusion of the .exe or the entire EOS Utility folder do not help. So now I am looking for some other AniVirus. Any recommendations? Until now I have been satisfied with AVG.
Have Win 7 and Win 8.
07-10-2015 08:33 AM
@mad_marten wrote:now I am looking for some other AniVirus. Any recommendations?
I use Avast, it's free, and it does'nt hamper any of my Canon software. I'm surprised AVG would do that.
07-10-2015 08:40 AM
@mad_marten wrote:My EOS Utility, both 2 and 3, works when I disable AVG.
Are you saying you have EOS Utility 2 & 3 installed on the same Pc???
